The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (51sub, DaveV, 4112YR, 52_Ton, 2 invisible), 387 guests, and 3 spiders.
Forums48
Topics117,315
Posts938,042
Members42,899
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1949 3800 gas tank swap #1346480 Fri Feb 14 2020 02:08 PM
Erik Husker Offline OP
Ok. I have a 1949 3800 flatbed truck. I am wanting to move the gas tank out of the cab. I have thrown around a few ideas for the tank location. Mount duel tanks on either side of the frame behind the cab, on the flat bed, or use a 47-48 suburban style tank and mount inside the frame. If I do the inside the frame option, will the suburban style 16 gallon tank work? I know i might have to cut a notch in the flatbed mounting board to get it to come through. I see there are 2 braces on those frames to help hold the tank Can those be found anywhere? Thanks for any help and assistance.
Re: 1949 3800 gas tank swap [Re: Erik Husker] #1346533 Fri Feb 14 2020 08:35 PM
ASU Offline
This is my 48 3600 flat bed. I used a universal tank (u-4) from www.tanksinc.com. I built some angle iron brackets with a "dip" in them to lower the tank in the frame, and get the fill neck down to the top of the frame rail.
Jon
Re: 1949 3800 gas tank swap [Re: Erik Husker] #1346812 Mon Feb 17 2020 04:02 AM
Fox Offline
ASU,
How much space will there be between the deck and the tank? By the looks of it, if it was a pickup box that tank would likely be hitting the bed wood. How much driveshaft clearance is there?
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: 1949 3800 gas tank swap [Re: ASU] #1346833 Mon Feb 17 2020 01:38 PM
Thanks. Do you have any pictures of the brackets? My truck has a flat bed so i have a 4x6 attached to the frame and the box sets on top of that. I have toyed with either placing it like you did or up even higher since I have a bit more room
Re: 1949 3800 gas tank swap [Re: Erik Husker] #1346920 Tue Feb 18 2020 12:19 AM
ASU Offline
I have a flat bed too, but plenty of room. not the best pics, fluorescent lights in the garage don't like the cold... Brackets mounted to cross member at the back of the cab, and the cross member just ahead of the axle.
Re: 1949 3800 gas tank swap [Re: Fox] #1347341 Fri Feb 21 2020 02:13 PM
The tank will be raised up in the frame since I will have a 4x6 on the frame to raise up the flatbed frame.
Moderated by  Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
