The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (55 SHAKER, David C., Bogart's Truck, Apache1, Coltonk, 2 invisible), 385 guests, and 3 spiders.
Forums48
Topics117,315
Posts938,049
Members42,899
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1949 3600 well running stock truck #1343538 Sat Jan 25 2020 04:38 AM
Don huffer Offline OP
Well kept runs well. Repairs done right with stock parts. Almost original except for 16" wheels with new tires. Everything works in the gauges including the dash lights. All led lights except head lights. Extra break lights in bed sides. Safer. Doors close and seals are in place. Windows work replaced one regulator. Glove box door works well. Ash tray clean and well fitted. Interior is newly painted correct factory color. Have extra quart. Bench seat in excellent condition but not new. Thick cover not cheap new one. New stock headliner and center rib. Cab floor in great shape. Seals on vents. Vents open and close well. New stock gas tank fuel pump lines fuel filter best rebuilt carb. Paper filter in oil bath original air cleaner. PCV convert on draft tube. Runs better. Brand new grill assembly and bumpers. New hood emblem and center ss strip. New stock exhaust welded. Paint wet sanded and buffed. Mahogany bed ss bolts strips. Breaks working well. Drives straight great alignment no shake tight steering. Rebuilt drag link. Doesnt burn oil. Pertronix points hidden in stock distributor. Oil pan removed cleaned primed and painted. Sealed well and doesnt leak. Same with valve cover. Lots of new parts starter, generator, new Optima battery 9 months old. Large battery cables. New motor mounts. All new rewiring for everything except under dash. New head lights. Automotive wire used. Original wiper motor but needs rebuilt. Dome light works. New gas tank sending unit. 216 motor,
http://www.ebay.com/itm/293435869969?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Can’t begin to tell you how much I hate the name Stovebolt.
Re: 1949 3600 well running stock truck [Re: Don huffer] #1343703 Sun Jan 26 2020 02:59 AM
Grigg Offline
sold 17,500
Re: 1949 3600 well running stock truck [Re: Don huffer] #1346431 Fri Feb 14 2020 01:40 AM
moparguy Offline
Don, don't know if you're still monitoring the 'Bolt but Nice job on your truck. Followed your efforts throughout and can only say "Well Done". Shame to see it sold, but the new owner has a bargain. Likely better than they realize.
1970 340 Duster
1951 Farmall Super A
Moderated by  Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
