The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (55 SHAKER, 68ironhead, Johnny N, HandyAndy, 3 invisible), 383 guests, and 3 spiders.
Forums48
Topics117,315
Posts938,050
Members42,899
Most Online1,229
Jan 21st, 2020
Image Posting Policy
235 Camshaft #1346372 Thu Feb 13 2020 05:16 PM
John L. Offline OP
New in the box camshaft for a 235 small journal. Melling p/n CCS12 100.00 ships on your dime.
Re: 235 Camshaft [Re: John L.] #1347295 Thu Feb 20 2020 09:22 PM
EchoBravoSierra Offline
Is this for a splash oiler?
Re: 235 Camshaft [Re: John L.] #1347296 Thu Feb 20 2020 09:28 PM
tclederman Offline
Boltergeist
Looks like it is listed by Melling for cars: 1942-1953 216 & 1950-1953 216/235?
The listings do not show it for trucks.
The Master Parts Catalog shows that truck and car 216 cams were the same from 1937-1953.
The Master Parts Catalog shows 1941-1953 car and truck mechanical lifter 235 cams being the same (but, different from the 216 cam).
The Powerglide-equipped cars (50-53) had a different cam (and, they had hydraulic lifters).
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 235 Camshaft [Re: John L.] #1347357 Fri Feb 21 2020 03:55 PM
Thanks.
I'm trying to help a friend find a cam. Here's the deal- He's having a custom grind done by Isky, but the core he/they had to start with is bad, so there'll need to be a good one sourced to move forward. The block is a '46 truck 235, BUT it's been machined for insert bearings in the bottom end. I don't know the status of the cam bearings. I need to find that out before anyone spends too much mental energy on it.
Re: 235 Camshaft [Re: John L.] #1347474 Sat Feb 22 2020 04:17 PM
Hotrod Lincoln Offline
Boltergeist
Tim, the 235 cam has flat spots between the lobes to clear the connecting rods, due to the longer stroke on the 235. A small-bearing 235 cam would probably work in a 216, but not the other way around.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
