EVENTS
Check in for status!
Jump over to the
Events Forum , to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,216
Posts980,464
Members44,177
Most Online1,229Jan 21st, 2020
1937 Chevrolet pickup rear spring shackle problem
OP
I have a 1937 Chevrolet pickup the rear spring shackles have pushed outward . How to I fix this?
Qball
Re: 1937 Chevrolet pickup rear spring shackle problem
Red dot, center of chest ...
Looks like the bushings are worn out.
Are those original shackle plates? I have just finished my 37 and mine do not look like that. Also where are you located in Michigan? Bill
Pins and bushings are stuffed . Buy new ones . One of the vendors on this site will have them .
ace skiver
scroll all the way to the bottom for various 1937 spring/suspension parts.
Boltergeist
It also appears the rear shackle has took a hit to me..........take the shackle loose, make sure the springs align with the front shackle in correlation with the rear housing mount as well. A new set of bushings and plates should complete the job......and be sure to check out the front hangers as well.
FYI Those aren’t original shackles. The OEM have a single bolt in between the two bushings. And no rubber. Original spring mount was riveted on.
These old bolts are in my blood. Hard thing is focusing on just one. 1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
OP
Yes I am in Michigan I know the bushings are wore out but if I change them it will not solve the problem of the springs pushed outside of the frame
Qball
OP
I know that I need new bushings and springs but that doesn’t fix the problem of the springs being pushed outside the frame
Qball
OP
The front is good both rears look the same it’s almost like the springs moved out on the axle an inch on both sides is that possible?
Qball
