The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Capt Oblivious, Perro, Justhorsenround, 55shaker, 55_2nd_Series, Jeff Meng), 200 guests, and 3 robots.
Forums60
Topics123,367
Posts995,559
Members44,646
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1937 Chevrolet pickup rear spring shackle problem
#1345714 Sun Feb 09 2020 04:55 PM
Q
Quin Offline OP
I have a 1937 Chevrolet pickup the rear spring shackles have pushed outward . How to I fix this?
Qball
Re: 1937 Chevrolet pickup rear spring shackle problem
Quin #1345730 Sun Feb 09 2020 06:41 PM
Red dot, center of chest ...
Looks like the bushings are worn out.
Paul Schmehl CI 12
geek@stovebolt.com
Stovebolt Staff: Geek
1948 Chevy 3100 Five Window [stovebolt.com]
Quin #1345766 Sun Feb 09 2020 10:42 PM
Are those original shackle plates? I have just finished my 37 and mine do not look like that. Also where are you located in Michigan? Bill
Quin #1345769 Sun Feb 09 2020 11:23 PM
Pins and bushings are stuffed . Buy new ones . One of the vendors on this site will have them .
Quin #1345773 Sun Feb 09 2020 11:52 PM
scroll all the way to the bottom for various 1937 spring/suspension parts.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Quin #1345839 Mon Feb 10 2020 04:42 PM
It also appears the rear shackle has took a hit to me..........take the shackle loose, make sure the springs align with the front shackle in correlation with the rear housing mount as well. A new set of bushings and plates should complete the job......and be sure to check out the front hangers as well.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Quin #1345844 Mon Feb 10 2020 05:20 PM
FYI Those aren’t original shackles. The OEM have a single bolt in between the two bushings. And no rubber. Original spring mount was riveted on.
1937 Chevy 1/2 ton panel
Bill Trotter #1346151 Wed Feb 12 2020 03:39 PM
Q
Quin Offline OP
Yes I am in Michigan I know the bushings are wore out but if I change them it will not solve the problem of the springs pushed outside of the frame
Qball
tclederman #1346152 Wed Feb 12 2020 03:42 PM
Q
Quin Offline OP
I know that I need new bushings and springs but that doesn’t fix the problem of the springs being pushed outside the frame
Qball
Achipmunk #1346153 Wed Feb 12 2020 03:45 PM
Q
Quin Offline OP
The front is good both rears look the same it’s almost like the springs moved out on the axle an inch on both sides is that possible?
Qball
Page 1 of 2 1 2
Moderated by  KCMongo
