The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (carbking, 49shep, 5 Window 9434, J Lucas, ESum, 1 invisible), 267 guests, and 3 robots.
Forums50
Topics120,054
Posts961,531
Members43,545
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 7 1 2 3 4 5 6 7
1950 3100 parking brake
#1344029 Tue Jan 28 2020 06:42 PM
Jhyp Offline OP
I'm giving it another try. Looking for any help, thoughts, insights into fixing my parking brake.
Background: I have adjusted the rear brake cylinders so there is just a hint of drag. I have installed a new pb cable. The concentric bolt holding the pb lever is properly adjusted. Slotted rod attached to the front shoe is in place.
Problem: when the brake cable is fully engaged (ie the pb lever is almost touching the backing plate near the axle and can not move forward any further) the slotted rod which is connected to the pb lever does not engage the leading brake shoe. The lever does not travel the full length of the slot in the rod.
Observations: slotted rod needs to be longer or slot needs to be shorter or missing a piece or ?????
Help. As always thanks in advance.
Jon
Re: 1950 3100 parking brake
Jhyp #1344092 Wed Jan 29 2020 02:17 AM
Jon if you have any pictures (images) that will be helpful. I've repaired a few of these (including reconstructing one where the parts were missing), but I can't tell what yours might be doing (or not doing) without some help.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Jhyp #1344096 Wed Jan 29 2020 02:39 AM
The parking brake lever attaches to the secondary shoe. You mentioned a concentric bolt, but I'm not sure what that means.
Here's a picture that may help. Compliments of Brad Allen
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Jon G #1344106 Wed Jan 29 2020 04:28 AM
Jhyp Offline OP
klhansen, I will try and post some pics next week. I'm out of town.
Jhyp #1344107 Wed Jan 29 2020 04:29 AM
Jhyp Offline OP
Oops my last reply was ment for JonG.
Jhyp #1345514 Sat Feb 08 2020 12:27 AM
Jhyp Offline OP
Here are the pics of my problem.
First pic is of BP lever fully engaged (ie touching the backing plate and can not go any further)
Second pic (although hard to see) is the slotted rod with the BP fully engaged. The BP lever does not reach the back of the slot and therefore does not push on the brake shoe to push on the drum. What am I missing?
Jhyp #1345518 Sat Feb 08 2020 12:39 AM
Did you adjust the brakes before you started working on attaching the parking brake cables?
Though this may seem like a dumb question by some, it is very important.
Jhyp #1345566 Sat Feb 08 2020 03:53 AM
Jhyp Offline OP
I did adjust the wheel cylinders so there was just a hint of drag on the drums by the shoes.
Jhyp #1345645 Sat Feb 08 2020 10:17 PM
My guess is that since you are not able to cause the shoes to contact the drums by pulling on the disconnected cables, you may not have the mechanical parts between the drums and the backing plates installed correctly.
Jhyp #1345655 Sun Feb 09 2020 12:13 AM
Jhyp Offline OP
Thanks for you help. I'll look for a pic of properly installed mechanism and reassemble the parts accordingly.
Moderated by  SWEET
