The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (bucktruck, 49 3100, Brad Allen, 81tta, 46forme, 2 invisible), 171 guests, and 3 robots.
Forums50
Topics121,008
Posts970,105
Members43,813
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Need a small piece of the cab step.
Redline #1345339 Thu Feb 06 2020 11:52 PM
I do have the right. Are you interested in paying shipping on the whole thing? You might be better off looking abit closer if there is no rush. Looks like your in Texas
Redline #1345344 Fri Feb 07 2020 12:19 AM
Reason being is that id hate to cut up a perfectly good step for a random piece. eek
Redline #1345428 Fri Feb 07 2020 04:55 PM
Can you post a pic of the area you need?
ppp
triplep #1345440 Fri Feb 07 2020 05:55 PM
Redline Offline OP
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
Redline #1345454 Fri Feb 07 2020 07:07 PM
Im not cutting up a perfectly good step for that. Sorry. But i would suggest. Cutting a metal strip to fit under it and then fill with a welder. It might come out pretty decent. At least for the time being til you find a replacement step. Not sure how the rest of the truck is, but might not be worth fixing at all, just replacing.
Redline #1345466 Fri Feb 07 2020 08:03 PM
It wouldn't be that hard if one had access to a sheet metal brake to pretty quickly fab up a patch for that.
I had some similar damage and filled the holes with weld metal using a copper backer formed to fit underneath. It was a lot of work but came out acceptable. Glenns suggestion of a sheet metal backer would work too, but you might have a lot of cavities where moisture can hide and the rust continue.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Redline #1345554 Sat Feb 08 2020 02:27 AM
Replacement combo rocker, step and riser panels are available for you favorite vendor for about $70...that might be the fastest/cheapest way to go. I did both of mine (left and right) by drilling out all of the spot welds and welding the complete panel in. To me that was easier than trying to patch in the middle of a large mostly flat panel. I think I did have to remove the reinforcement channel that is welded under the step and transfer it to the new step.
Mike B smile
Redline #1345563 Sat Feb 08 2020 03:37 AM
Saw your picture . Would do for $20 plus actual shipping. Thanks
ppp
triplep #1345661 Sun Feb 09 2020 12:58 AM
Redline Offline OP
Thanks for your offer. I'll take it.
I tried to send you a PM but couldn't.
BL
Redline #1345849 Mon Feb 10 2020 05:28 PM
I cleaned up my pm s . I sent you a pm with phone # for text photos
ppp
Page 2 of 3 1 2 3
Moderated by  Tiny
