The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
29 members (bigscooter, Achipmunk, 78buckshot, 52Carl, Abelsclassic, 1 invisible), 199 guests, and 3 robots.
Forums50
Topics120,602
Posts966,687
Members43,711
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1956 GMC Vent Window Parts Needed
#1345237 Thu Feb 06 2020 02:23 PM
sack Offline OP
Looking for spring and stop washer that goes on vent window stud that holds the bottom into the frame. Tried to find a new replacement, had no luck. Can someone point me in the right direction for these parts.
These are the only parts holding up the window install
Re: 1956 GMC Vent Window Parts Needed
sack #1345267 Thu Feb 06 2020 04:21 PM
The Truck Shop has the spring in their catalog.
Fred
sack #1345291 Thu Feb 06 2020 05:50 PM
sack Offline OP
Thanks at least I can get the spring The vent window stop washer is going to be a tough one has a square hole and a wing to stop window from traveling to far and then a couple of square hole washers. The quest goes on.
sack #1345315 Thu Feb 06 2020 07:52 PM
If you can't find one close or quickly, I can knock one apart.
sack #1345332 Thu Feb 06 2020 10:32 PM
sack Offline OP
Thanks Jeff
I will PM you if I can not find parts close by
sack #1346003 Tue Feb 11 2020 07:18 PM
Sack, I have my original vent windows that I won't be using. I will also take one apart and send you what you need. I also have an NOS vent window assembly that's in the yellow/black GM box that I won't be using. I could never find the other side. I'm not sure if it's the driver or passenger side.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
sack #1346019 Tue Feb 11 2020 08:37 PM
sack Offline OP
Thanks for the offer .Found some parts local, that were sitting in a friends pile of saved junk (as he says )
So I should be all set .
Moderated by  Tiny
