EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,183
Posts980,103
Members44,168
Most Online1,229 Jan 21st, 2020
 1956 GMC Vent Window Parts Needed
OP
Looking for spring and stop washer that goes on vent window stud that holds the bottom into the frame. Tried to find a new replacement, had no luck. Can someone point me in the right direction for these parts. These are the only parts holding up the window install
 Re: 1956 GMC Vent Window Parts Needed
The Truck Shop has the spring in their catalog. Fred
OP
Thanks at least I can get the spring The vent window stop washer is going to be a tough one has a square hole and a wing to stop window from traveling to far and then a couple of square hole washers. The quest goes on.
If you can't find one close or quickly, I can knock one apart.
OP
Thanks Jeff I will PM you if I can not find parts close by .
Sack, I have my original vent windows that I won't be using. I will also take one apart and send you what you need. I also have an NOS vent window assembly that's in the yellow/black GM box that I won't be using. I could never find the other side. I'm not sure if it's the driver or passenger side.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
OP
Thanks for the offer .Found some parts local, that were sitting in a friends pile of saved junk (as he says ) So I should be all set .
