The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (JosN, chaz71, wave1957, ASU, 1 invisible), 212 guests, and 2 robots.
Forums50
Topics122,183
Posts980,102
Members44,168
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1956 GMC Vent Window Parts Needed
#1345237 Thu Feb 06 2020 02:23 PM
sack Offline OP
Looking for spring and stop washer that goes on vent window stud that holds the bottom into the frame. Tried to find a new replacement, had no luck. Can someone point me in the right direction for these parts.
These are the only parts holding up the window install
Re: 1956 GMC Vent Window Parts Needed
sack #1345267 Thu Feb 06 2020 04:21 PM
The Truck Shop has the spring in their catalog.
Fred
sack #1345291 Thu Feb 06 2020 05:50 PM
sack Offline OP
Thanks at least I can get the spring The vent window stop washer is going to be a tough one has a square hole and a wing to stop window from traveling to far and then a couple of square hole washers. The quest goes on.
sack #1345315 Thu Feb 06 2020 07:52 PM
If you can't find one close or quickly, I can knock one apart.
sack #1345332 Thu Feb 06 2020 10:32 PM
sack Offline OP
Thanks Jeff
I will PM you if I can not find parts close by
sack #1346003 Tue Feb 11 2020 07:18 PM
Sack, I have my original vent windows that I won't be using. I will also take one apart and send you what you need. I also have an NOS vent window assembly that's in the yellow/black GM box that I won't be using. I could never find the other side. I'm not sure if it's the driver or passenger side.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
sack #1346019 Tue Feb 11 2020 08:37 PM
sack Offline OP
Thanks for the offer .Found some parts local, that were sitting in a friends pile of saved junk (as he says )
So I should be all set .
Moderated by  Tiny
