The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (Harold41, David C., 2ManyTrucks, 4100 Fire Truck, 2 invisible), 393 guests, and 4 spiders.
Forums48
Topics117,315
Posts938,048
Members42,899
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Water Pump Relocation Adapter #1344842 Mon Feb 03 2020 06:02 PM
Pre '68 Dave Offline OP
When installing a 1955-62 235 or 1955-63 261 full pressure engine in place of a 1937-54 216 or 235 engine, this conversion allows you to put the early high mount style pump on the later engine.
In the past modifying the 1955-62 water pump was done but required a press to force the hub further back on the shaft, then the hardened shaft required being cut off. Additionally a special pulley and fan was required. After all that the pump and fan still sat 3" lower than the 216 or early 235 pump and that could lead to overheating and possible fan hum.
By using my water pump relocation adapter plate with a 1941-54 water pump, the pump is put back in the stock location. Additionally if you need to replace the water pump in the future you can buy an over-the-counter pump and install it without modification.
Another advantage of using this relocation adapter plate and a stock pump is the stock lower radiator hose can be used. (The modified 1955-62 pump has a larger connection for the lower hose so a special hose is needed.)
Note: When installed in a 1939-40 Chev, the fan will be ¼” forward from stock but will fit fine.
Installation requires drilling and tapping two holes in the engine block.
The carbon in the cast iron keeps the drill bit cool, so no water or lubricant is necessary.
Low RPM drilling works best.
Note: I recommend using the harmonic balancer and water pump with the belt width you want from your original engine.
1941-52 ⅝" belt
1953-54 ⅜" belt (An acceptable substitution is to use a 1955-62 truck balancer. It is designed for a ½” belt and may be used with a ⅜" belt. This will allow the belt to run deeper in the groove and in effect will reduce the diameter to very near the correct size).
1937-40 must use one of the above
Caution: I do not recommend using the 1955-62 passenger balancer since the pulley is larger and may turn the fan too fast, leading to cracking. (to identify this balancer, the pulley is 6 3/4" OD X 5/8" outside to outside edge).
Adapter plate $40.00 plus $7.75 FR shipping.
You can PM me if you would like to buy this adapter directly from me, or have any additional questions.
Thanks, Dave
Picture of plate installed.
My Blog
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1344843 Mon Feb 03 2020 06:13 PM
Achipmunk Offline
...for those interested. I have used Dave's adapter plate on my 1956 261 engine and it is a wise move. Works great on my 261 and as he mentioned, water pumps are available from your local parts house. Works great.
Dave, thanks for your work on this.
...and drilling the hole was no problem.
Pictures in my Photobucket
52 Chevy Panel
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1344848 Mon Feb 03 2020 06:42 PM
tclederman Offline
Boltergeist
It looks like someone has copied Dave’s invention, and is listing it for sale on eBay.
Dave’s plate has a lower total cost, after adding shipping cost.
Support the inventor - Pre ‘68 Dave.
I have installed Dave’s plates on three 1955-2nd and newer 235/261 engines. This is an invaluable conversion for using a high-pressure 235/261 on/in a 1955-2nd or earlier Chevrolet truck.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1344859 Mon Feb 03 2020 09:45 PM
Green_98 Offline
I used it on my 261, worked perfectly.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1344881 Tue Feb 04 2020 12:25 AM
Bill Trotter Offline
I also used it on my 37 with a 57 235. Worked great and Dave was a great help with questions. Thanks Dave
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1344883 Tue Feb 04 2020 12:35 AM
Phak1 Offline
Jack of all Trades, Master of None
I also used Pre ‘68 Dave’s plate and it works great. I also want to support the inventor, who is one of us bolters. Dave sells it off of eBay look so for “pre68dave” as the eBay sellers name.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1345852 Mon Feb 10 2020 05:47 PM
Shaffer's1950 Offline
Used on my 1959 chevy 235. Easy to install. Dave also answered questions before I did the adapter!! Support one of our Own..
Re: Water Pump Relocation Adapter [Re: Pre '68 Dave] #1346366 Thu Feb 13 2020 04:39 PM
Hotrod Lincoln Offline
Boltergeist
The pressed-on cast iron pulley on that 216 style water pump can be modified by machining it to accept a 2-sheave stamped steel pulley for a small block Ford V8. With a 2-groove harmonic balancer from a 250 inline six adapted to the earlier engine, that allows for some creative belt routing for air conditioning, power steering, etc.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
