The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (32vsnake, Achipmunk, Bolter Finally, Alainfrenchie54, Cletus1950, 2ManyTrucks, 1 invisible), 134 guests, and 3 robots.
Forums60
Topics124,614
Posts1,005,764
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: distributor block off plate for 292
mick53 #1344113 Wed Jan 29 2020 05:26 AM
mick53 Offline OP
This is my oil pump. The screw adjust the oil pressure that remains constant. There is also a fitting on the back that drives the cable drive fuel pump. This is driven by a pulley on the crankshaft. Four hoses go to the oil pan. There is no oil in the pan. It is stored in a 3 gal remote tank. The pump creates a vacuum in the crankcase to stop windage and help the rings seal better. The oil is on a thermostat like your radiator for quick warm up. You can also put an oil preheater on it if you want to start with warm oil. They say 80% of engine wear happens before your engine reaches temp. Hope that helps to explain it. Thank you for your time.
mick53 #1344144 Wed Jan 29 2020 03:42 PM
I had forgotten that, I seen those pictures earlier. Freeze plug down the hole would be fast and easy, or a machined plug with o-ring seal. Make the plug long, slot the bottom, drill a hole down the center, and thread a wedge to pull up into the slots with bolt down center. You would end up with plug and single bolt showing, o-ring seal and fingers wedging it into place.
mick53 #1344203 Wed Jan 29 2020 10:23 PM
mick53 Offline OP
Here is my complete ignition system. You can see why I need to plug the hole.
mick53 #1344556 Sat Feb 01 2020 02:27 PM
Is there a build log for this truck? I couldn't find anything.
mick53 #1344564 Sat Feb 01 2020 03:55 PM
Crusty Old Sarge
I see dollar signs $$$$$, lots of dollar signs $$$$$.$$. grin
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
mick53 #1344607 Sat Feb 01 2020 11:44 PM
Crusty Old Sarge
If you haven't mounted the oil pan yet just thread the distributor hole and fit it with a pipe plug.
Craig
TUTS 59 #1344744 Mon Feb 03 2020 12:54 AM
mick53 Offline OP
That's pretty much what iv'e done with everything else.
mick53 #1344781 Mon Feb 03 2020 04:27 AM
As said before - - - may - be use a smaller size freeze plug .
I did see a picture of your engine with the carbs & blower attached . mick - - would you have a photo of the right side of your engine with that same set - up ?
just checking - - - - and, a very cool 292 . . . . . . Best of luck with your whole build .
later, jim
Twinshadows #1344882 Tue Feb 04 2020 12:27 AM
mick53 Offline OP
later, jim
Things have changed since then. I have a 12 port crossflow aluminum head from New Zealand being machined now. It's the first of it's kind. 10 years in R&D. same 4-71 blower and 3-2bbl carbs.
Page 2 of 2 1 2
Moderated by  KCMongo
