The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (bolter5410, 50wudy, Bumpa49, Alainfrenchie54, 78buckshot, 2 invisible), 210 guests, and 3 robots.
Forums50
Topics118,875
Posts951,520
Members43,285
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 5 1 2 3 4 5
Re: New gas gauge does not work
glennj3 #1343830 Mon Jan 27 2020 02:49 AM
ace skiver
This post might help.
Is you truck 6v or a 12v conversion?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1343844 Mon Jan 27 2020 04:58 AM
The extra bulb might be the one for the ignition switch.
glennj3 #1343876 Mon Jan 27 2020 02:36 PM
There is a bulb in the ignition switch mount. Check that to see if your extra bulb goes there.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
glennj3 #1343885 Mon Jan 27 2020 03:28 PM
glennj3 Offline OP
I’ll look , I pulled the ignition switch out to make room to put the speedometer back in. I didn’t notice anyplace foe a light but I’ll look again.
I don’t think that wire will even reach the ignition switch.
1953 Chevy 153A, 3/4 ton, 4 stick in the floor. Not original engine, has a strait 6 chevy engine with a Ford Carburetor.
glennj3 #1343904 Mon Jan 27 2020 06:57 PM
ace skiver
Tim
glennj3 #1343910 Mon Jan 27 2020 07:44 PM
The 47-53 ignition switch bracket has a hole to snap a light in. Not on switch itself. John
1949 gmc 1-ton
glennj3 #1343919 Mon Jan 27 2020 09:07 PM
glennj3 #1343920 Mon Jan 27 2020 09:12 PM
ace skiver
Is that your YouTube video, DADS50 - nice - thanks.
Tim
tclederman #1343922 Mon Jan 27 2020 09:23 PM
Just a quick video showing the location of the bulb, I think i made the vid the show the no key function on some ignitions, but is shows the instrument bulb also.
glennj3 #1343930 Mon Jan 27 2020 11:24 PM
glennj3 Offline OP
The ignition switch light holder must be an extra add on?
Regarding the gas Gauge🙁😮. This one is new, it does not move no matter what I do (ground the tank wire, the gauge is grounded). I connected my old new gauge to power and touched the sender to the tank gauge and it moved to full. I connected my electric gauge the same way and it read full. My tank is over 1/2 full. I can’t believe this new gauge does not work. I have two new gauges but I thought I burned one up. It did not work when I had it in the instrument. Now it does outside of the instrument.
I just hate to remove the whole instrument to replace the fuel gauge again! I want to make sure it is a bad gas gauge before I remove it again.
Thanks for your assistance!
It has power and the sender wire has continuity.
Moderated by  Rusty Rod
