The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Johnny N, JoeFranklin, KEVINSKI, Jon G, heidel410, 1 invisible), 135 guests, and 4 robots.
Forums50
Topics119,515
Posts956,958
Members43,424
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 4 1 2 3 4
Steering opinion?
#1343540 Sat Jan 25 2020 04:55 AM
jmlloar Offline OP
Trying to figure what is the best way to go with power steering conversion.
Who is using what and good and the bad of your setup?
Looking at ones with solid front axle not ones swapped to independent.
Should I use the factory location conversion or the swap using newer style front mounted box?
1955 GMC 150, 1980 Chevy C10, 2011 Sierra 3500 HD SLT Duramax Dually Crewcab, 1960 Chevy BelAir 2dr sedan, 1978 Pontiac Trans-Am
Re: Steering opinion?
jmlloar #1343546 Sat Jan 25 2020 05:33 AM
One of the easiest and most popular is the mid 80's Toyota 4wd box. Fits in the same place as the factory box with simple modification. Do a search.
Evan
jmlloar #1343555 Sat Jan 25 2020 01:24 PM
If you give us your truck layout, engine, etc., size, it would help.
Ed
jmlloar #1343556 Sat Jan 25 2020 01:31 PM
jmlloar Offline OP
My truck is 55.2 GMC 150
2002 GMC 5.3 LM7
4L80E
Stock front suspension
Stock rear suspension with 9.5 in 14 bolt semi float rear 3.73 gears
I've got plenty of clearance for either setup I just wanted some opinions on how everyone likes the setup they have before spending the money to swap mine out.
jmlloar #1343559 Sat Jan 25 2020 01:43 PM
I used a power steering kit from CPP for my 51 panel.
Also, upgraded the brakes to discs at that time.
No drama on the install and steered like a Cadillac. And, stopped on a dime.
Squire #1343562 Sat Jan 25 2020 02:06 PM
jmlloar Offline OP
I'm up for the disk brake swap but still working out details. Since mine is 8 lug its more of a challenge. Looking at probably using 88 up rotors on modified factory spindles. That will be my next challenge. At the moment steering needs to be decided on to determine which headers I use for clearance.
I like the looks of the CPP kit but I have access to 2wd truck steering box for the other swap.
jmlloar #1343588 Sat Jan 25 2020 05:27 PM
General Purpose
I did Disc front. I did the power steering that uses an owner purchased Saginaw box on a 1956 GMC.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
jmlloar #1343593 Sat Jan 25 2020 06:28 PM
I'm using an 86' C10 Saginaw box with a kit from Brothers Truck. So far the only draw back I see is that you need to reinforce the frame at the mounting position. I am still working that out. The drag link and pitman arm were straight forward, just adjust the length and your good to go.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
jmlloar #1343641 Sun Jan 26 2020 12:08 AM
If you choose to use a CPP kit, make sure that your kingpins aren't worn out. The power steering gets swimmy if they are worn. This is annoying because it adds to the lack of road-feel inherent to driving with the Saginaw p/s box.
I removed the original caster shims and replaced them with 6 degree caster shims. This greatly improved the feel of the road. Now when I come out of a turn, the wheels return toward the straight ahead position just like the stock manual steering box does.
TUTS 59 #1344372 Fri Jan 31 2020 01:23 AM
jmlloar Offline OP
I can see reinforcing the mounting point. The GMC I'm working on has a much larger front cross brace engine mount than what is on a comparable chevy. But if going that route I will definitely beef it up , thanks.
I was told about the degree shims to help out with caster. But I seem to remember that only 4 degrees was recommended.
Page 1 of 4 1 2 3 4
Moderated by  SWEET
