The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (D B Cooper, Hambone, cmayna, John W. Bottger, 2 invisible), 232 guests, and 3 robots.
Forums47
Topics117,641
Posts941,058
Members43,016
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Heres what i got
#1343128 Tue Jan 21 2020 05:48 PM
So i've been on and off this website but i still own 2 51' GMC pickups. One is a barn find full original 51' 3 window all intact and hasn't run in 40 years. My goal was to buy a frame, build it up and use the barn find body over the new frame build. I find the frame, partial built up with a mustang II front end, disc brakes, a rear end out of a camaro, new leaf springs and cross member. However, the frame purchase came with an entire truck with 5 windows!!!!!!!!! darn, now a dilemma!!!!!! Both are long beds. Soooooo, my new plan is to build the 5 window, modernize it like it's been started and to eventually take the barn find and restore to originality, Boy will i be busy for the next several years!!!!!! So, my question to all of you, since this is my first frame off restoration..............what references are out there to be able to systematically finish the frame so i have everything done before I start on the cab, then install on frame and then the bed would follow. I would like to relocate the gas tank to the rear and take suggestions on what seating works and so on....... I will post pics as to what I have and will rely on your input to get me going...... thanks for your time.
Barry
1951 GMC 3 window 100
1951 GMC 5 window 100
Re: Heres what i got
turnintotruckin #1343131 Tue Jan 21 2020 06:23 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Barry, welcome back. The Welcome Center is not the best place for asking questions. Probably less than 10% of the membership comes back here after the initial howdy. Since you are doing a restomod the HiPo Forum has some good folks who are very knowledgeable about these projects.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
turnintotruckin #1343185 Wed Jan 22 2020 02:50 AM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Welcome to the 'bolt (err, back to the 'bolt).
As Justy said, this isn't the best place to ask questions.
Just so we understand, you have TWO complete trucks and a Hotrodded frame?
Are you asking about re-habbing the barn find frame? or the hotrodded frame? or both?
I would start by looking through a shop manual.
I power washed everything before I started.
When I did my 39 pickup, I tore it down as far as I needed... bagging and tagging as I went. I also clean up, paint and polish as I take it apart.
I cleaned the frame by wire wheel, oven cleaner and elbow grease. Then painted the whole thing with POR-15. I installed a M-II front end but used the rear springs adapted to a more modern rear end. Replacing the worn bushings ect. I also replace the fuel and brake lines front to rear.
Another quality post.
Real Trucks Rattle
turnintotruckin #1343199 Wed Jan 22 2020 05:22 AM
ok thanks, ill do that
turnintotruckin #1343362 Thu Jan 23 2020 05:27 PM
I recently ordered a 1947 -1954 Truck assembly Manual I believe from Brothers, it is over an inch thick and has been a valuable asset. I think it was brothers but, if you can't find it, I will try to find out which vendor. Also old trucks that are restored don't rattle. A 12x12 sheet of full grain cow hide and LMC frame gasket kits will solve all squeaks, rattles and bangs.
Started with a 1929 Chevy sedan when 15, moved on to various 216 & 235's one was a beautiful 1942 coupe. Primarily have Shelby's 427 AC,GT 350's etc. High performance 283 and 327 Chevy's in 1957 150 body. Model B Rochester carb. fanatic.
turnintotruckin #1343363 Thu Jan 23 2020 05:29 PM
Good luck and have fun, these old trucks never make me angry or upset, make it therapy and don't be in a rush. This is not a television has to be done by a certain date.
turnintotruckin #1343396 Fri Jan 24 2020 01:26 AM
Welcome to the Bolt, Mark. Been here for years and know that many here have done exactly what your doing. Be patient and visit often. No such thing as a stupid question either. We've all asked them too.!!!
Pictures in my Photobucket
52 Chevy Panel
turnintotruckin #1343444 Fri Jan 24 2020 03:50 PM
Big Bolt Forum Moderator
welcome back!!
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
