The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Darth Plasma, Flatblu4748, 55_2nd_Series, Gyrene, 60ApacheC20, 1 invisible), 110 guests, and 3 robots.
Forums50
Topics120,522
Posts966,061
Members43,692
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Slot in Grease Zerk
#1343389 Thu Jan 23 2020 11:05 PM
What is the slot cut in the threads of a grease zerk for? Overflow when "full?"
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving but now on hiatus. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Re: Slot in Grease Zerk
Wally / Montana #1343390 Thu Jan 23 2020 11:28 PM
Don't really know. Maybe meant to be self tapping?
1949 gmc 1-ton
Wally / Montana #1343404 Fri Jan 24 2020 02:31 AM
Doesn't look like self-tapping. I've never seen anything like that, but I have seen self-tapping and drive-in zerks. That looks like it would leak grease out alongside the threads. Not normally what you want.
Is that a new zerk or did you pull it out of something?
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1343439 Fri Jan 24 2020 03:11 PM
It's a new zerk but I don't know when or where I got it.
Wally / Montana #1343464 Fri Jan 24 2020 08:22 PM
When I saw this I was curious, so I looked it up. This is what I found: "vented grease fitting. Safety vent fittings have a vent slot in the threads that allow bearings to be filled without building up internal pressure." I usually look for grease to come out of the other side when I'm filling a zerk, I guess the vent is needed when there is no other side!
1947.2 Chevy Panel Truck 1 ton
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Wally / Montana #1343471 Fri Jan 24 2020 08:42 PM
Thanks for the update Walter. I tried to look in up also.
I learned thru training, that bearings with too much grease, will get hot.
That can lead to premature failure.
Another reason is, if the bearing has a seal on the other side, such as a wheel bearing.
If it is over greased, in could blow out that seal.
These were probably used on pedestal bearings, to prevent a seal blow out.
If anyone has any more info, I would like to hear it.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Wally / Montana #1343474 Fri Jan 24 2020 08:49 PM
I guess I can understand that, such as avoiding blowing out a seal, but you wouldn't want to use something like that on say a ball joint or tie-rod end. New grease wouldn't be able to reach the wear parts, because it would just short circuit out thru the vent slot.
But Hey, even us old timers can learn something new. wink
Wally / Montana #1343481 Fri Jan 24 2020 09:55 PM
Same way on spindle bearings if they had vent zerk fittings. It would sling out the grease.
Bearing buddies on boat trailer will work good if they have a dust seal to keep out dirt and water.
The extra grease blows by the seal. And makes a mess on the rim.
If they have a seal to keep in grease, the extra grease in, it can push the seal out and make a bigger mess.
Plus lets dirt and water in.
Best way to pack any bearing hub, is by hand. Boat trailers need to be inspected/packed at least once a year.
This is just my theory, so take it with a grain of salt.
Don
"The Flag Pole"
'50 2-ton flatbed
Wally / Montana #1343482 Fri Jan 24 2020 10:05 PM
To add some more.
Ball joints, tie rods, kingpins and any kind of bushing, needs the pressure, to get the grease where it needs to be.
Don
"The Flag Pole"
'50 2-ton flatbed
Wally / Montana #1344318 Thu Jan 30 2020 07:18 PM
I have seen this on farm equipment and after market zerk's. My best guess would be to keep the area around fitting clean. May be not.
Currently making 1954 3100 better than new
Moderated by  Justhorsenround
