The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (bwilliams, Craig1948RK, archburycontrol, delky, DougH6100, Connielu), 373 guests, and 3 spiders.
Forums48
Topics117,367
Posts938,489
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Horn not working #1343088 Tue Jan 21 2020 06:31 AM
ApacheFiend Offline OP
1958 Apache with "snail" Horn.
It worked before I had to shelve everything in 2013 when the engine crapped out. Now when I hook up the horn I just hear the relay click when I press the horn button. I tried cleaning up the contact point. If I try jumping power to the contact point and ground the horn assembly, I get nothing. Can you rebuild the old horns, or should I shop for a modern hi and low note horns setup? Recommendation on new setups? Thanks for the help!
58' 3200 235 3-speed/OD
Re: Horn not working [Re: ApacheFiend] #1343093 Tue Jan 21 2020 11:58 AM
moparguy Offline
A trick I've had luck with about half the time. Find the tone adjustment screw on the horn. It's likely a screw the side of the horn with no apparent purpose. Then while your ace helper presses the horn button, adjust the tone screw. Just turn it one way then the other.
As mentioned, I've had pretty good luck with this bringing a supposedly junk horn back to life.
Good Luck,
RonR
1970 340 Duster
1951 Farmall Super A
Re: Horn not working [Re: ApacheFiend] #1343115 Tue Jan 21 2020 03:29 PM
Wally / Montana Offline
My horns didn't work when I got the '48. I slipped a razor blade between the 2 flat pieces of vibrating Bakelite (?) to free them up.
That worked for about 27 years but I've developed (or re-developed) a problem and the horns are now iffy. It seems more like a contact problem at the steering wheel, though.
28 Years of Daily Driving. Now with a '61 261, 848 head, Rochester Monojet carb, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Re: Horn not working [Re: ApacheFiend] #1343148 Tue Jan 21 2020 08:40 PM
Tommy Offline
I have a horn set up out of a chevy trailblazer, it's two horns on a bracket very loud.
Tommy
59 apache 1/2t
261 short stepside
Re: Horn not working [Re: ApacheFiend] #1343656 Sun Jan 26 2020 12:46 AM
Fiddlerpin Offline
Find the adjustment screw. Sometimes it's inside the horn. You will have to remove the cover by prying out the metal crimps on each side. There will be an adjustment nut and screw. You will have to adjust one way or the other about 1/8 turn at a time until you find the sweet spot and the horn will work again. I have fixed many of them that way.
Re: Horn not working [Re: ApacheFiend] #1344116 Wed Jan 29 2020 06:36 AM
***** Update ***** After looking up different video on repair old horns, I removed the cover on mine and found it was very rusty. Everything in there has come kind of corrosion on it. I don't have the tools to do the best job on cleaning it all up. I found a few restoration services online, but they all want around $250-$300 to do a repair/restoration. So for now I have shelved the unit and I went with some of these: Hella Trumpet style horns: Universal Kit I wired them up and they work loud and clear.
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
