The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (klhansen), 93 guests, and 3 robots.
Forums50
Topics120,550
Posts966,276
Members43,699
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 666 of 695 1 2 664 665 666 667 668 694 695
Re: What did you get done on your bolt today????
BIG CHEVY 3600 #1330784 Tue Oct 22 2019 05:08 PM
Got the radiator repaired and back in the truck a couple of weeks ago, and finished putting the top support and the hood on today. I noticed the generator was wobbling, so I tightened that up, as well as a small fuel leak at the carb. I went for a quick ride around town, and I’m again a very happy Bolter. Nothing better than driving these old trucks!
1938 Chevy 1/2 ton
She looks good at 50 yards and 35 miles per hour on a dark night.
BIG CHEVY 3600 #1330798 Tue Oct 22 2019 07:51 PM
I removed the torsion bar suspension on my 1960 Apache shortbox, I got an 1987 suspension bolted in over the weekend.
BIG CHEVY 3600 #1333409 Tue Nov 12 2019 12:32 AM
Fitted up the grill after painting. Gotta make a few more adjustments but great progress.
1951 Chevy 3100
BIG CHEVY 3600 #1334862 Fri Nov 22 2019 09:43 PM
Finished up the windshield washer jar install...
BIG CHEVY 3600 #1340293 Fri Jan 03 2020 07:53 PM
Removed the rusty, crusty tailgate chains and spent about an hour with them on the wire wheel. Soaked them in a jar of clean 30 weight, then wiped them down and reinstalled them. They turned out great!
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
BIG CHEVY 3600 #1340998 Wed Jan 08 2020 03:20 AM
So yesterday and today were very productive. With the help of some good friends, we were able to pull the front clip off and get the engine pulled. Put the engine on the Cradle and loaded it into my other truck to take to the machine shop in the morning. I will try adding some pictures soon.
Thanks to the Stovebolt nation for all your help and support!
Brian Moore
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
BIG CHEVY 3600 #1341026 Wed Jan 08 2020 08:27 AM
Installed custom fabricated 3" lowering blocks on the 10 bolt rear end, ('81 Camaro) on my '50 3100. I'm using the original leaf springs. I've replaced all of the bushings...nice and tight. As you are probably aware, the leaf spring pin is not centered on the spring. To maintain the original wheelbase, 116", I had to have the blocks made so that I could properly locate the 10 bolt and still utilize the leaf pin for "securing" it if you will to the axle. I fudged to 117" since I'm going to 18" rear wheels. I prefer to maintain the original look as far as wheelbase.
BIG CHEVY 3600 #1342904 Mon Jan 20 2020 04:02 AM
Gave the '51 a little love today. Changed oil and by-pass filter. Adjusted valves using Hotrod Lincoln's method. Cleaned and adjusted points. Checked compression.
Really happy with the compression test. 1st one in 6 years of ownership and about 15k of driving. After changing the 15w40 diesel oil and driving 10 miles or so to get things up to temp for the valve adj. session all cylinders were 120 to 125 psig dry. I was hoping for 100 psig.
RonR
1970 340 Duster
1951 Farmall Super A
BIG CHEVY 3600 #1342909 Mon Jan 20 2020 04:27 AM
Last few days I worked on getting the kink out of the center of the bumper apron I picked up on my mega-road trip this past spring.
Needed some way to push the flanges apart. First tried a single threaded affair tacked in place. Had some success, but not enough (Photos #1 & 2). Then dreamed up a pulling fixture so I could flatten the bulge where the flanges got pushed together. Had more success with that. I spread the all-thread pushers out so I had room for hammer and dolly work after pulling a bit. More photos.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
BIG CHEVY 3600 #1342910 Mon Jan 20 2020 04:30 AM
For final straightening, I pulled out my running board press gizmo. Just about done, except for a bit more finishing hammer work.
Moderated by  Justhorsenround
