The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (49nut, DennisM, carbking, 68ironhead, Justhorsenround, 1 invisible), 96 guests, and 3 robots.
Forums50
Topics119,605
Posts957,732
Members43,440
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Torque tube to open shaft conversion
#1342516 Fri Jan 17 2020 01:47 AM
Hi . My buddy has a 2 ton 53 with a sm420 trans. and an open drive shaft. I have a sm420 set up for a torque tube. Can we change the rear bearing retainer and use my trans as a replacement? His has a parking drum on the rear of the box. Are the output splines the same? Will the PTO bolt up? I guess i'll find out when it gets warm enough to pull his out. His won't stay in 2nd gear . Thanks, Chip
Re: Torque tube to open shaft conversion
47fivewindow #1342567 Fri Jan 17 2020 03:14 PM
Novak has 420 rebuild kits.
Ed
47fivewindow #1342568 Fri Jan 17 2020 03:46 PM
Boltergeist
Yes, everything ahead of the bearing retainer is the same. I got involved in the conversion recently, but the other way- - - -changing an open driveline 420 to torque tube drive. Do not discard the front universal joint yoke used with the torque tube- - - -it's unique to the 420 transmission, and it's very scarce! The joint cross and the rear yoke are the same as a 1/2 ton, but not the front!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
47fivewindow #1342575 Fri Jan 17 2020 05:29 PM
Good info to pass on Jerry, I might add that if he plans to retain the parking drum and related appurtenances, of his bigbolt he will need the top loader off the original transmission unless the donor trans has the shaft for the brake handle. I have never seen a fine spline sm420 but a couple late models have them.Also even the sm420s found in 1/2 ton had a side cover pto provision that is identical. Basically sm420 from 1/2 tons on up to 2 tons are identical sans the rear bearing cover and ujoint for the enclosed driveshaft, and top cover for the hand brake.
Like Jerry says save the yoke and bell type rear bearing cover found in 1/2 and 3/4 ton trucks pre 55, getting hard to find.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
47fivewindow #1342732 Sat Jan 18 2020 05:49 PM
Thanks for the replies. I'll keep you posted when we get into it . Baby it's cold outside! Snowing in Maryland
47fivewindow #1342742 Sat Jan 18 2020 07:34 PM
7
It got cold here for a couple of days, eight inches last night now raining, too sloppy to get the truck out of the barn.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Moderated by  SWEET
