The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 registered members (Buckkoo, Dragsix, Bill Bishop, 1952Cecil, Corey41, exgenius), 353 guests, and 3 spiders.
Forums48
Topics117,476
Posts939,082
Members42,867
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Search question #1342403 Thu Jan 16 2020 07:40 AM
klhansen Offline OP
So I was trying to search for "open gear & chain" lube but get a ton of hits, for each word individually.
Many search functions let you search for a phrase by enclosing it in quotes, but apparently that doesn't work in the search function here.
I found some at Amazon after someone had mentioned using it and I thought, I should try that for ....., but I can't remember for the life of me what I was going to use it on. frown
Any suggestions?
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: Search question [Re: klhansen] #1342412 Thu Jan 16 2020 12:46 PM
Tiny Online
Global Mod
I just did a search using the search at the top of the page. I used this: "open gear & chain" and got only one hit, this thread.
Re: Search question [Re: klhansen] #1342418 Thu Jan 16 2020 01:47 PM
John Milliman Offline
Founder/Developer
What about chain saw bar oil?
'49 Chevrolet 3804
Re: Search question [Re: klhansen] #1342426 Thu Jan 16 2020 02:24 PM
Phak1 Offline
Jack of all Trades, Master of None
I have also experienced problems doing searches using the quote function. Sometimes it works and sometimes it doesn’t. I have no examples to show at this time. I have found posts in the past using the + function that I couldn’t find using the quotes and yet the exact phrase I quoted was in the posts.
However, if your looking for Open Gear And Chain Lube, I use it on my lathe gearing and it comes in a spray can. Heres a link to something simuliar.
CRC Open Gear & Chain Lube
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Search question [Re: klhansen] #1342480 Thu Jan 16 2020 08:25 PM
klhansen Offline OP
John & Phil
I found the stuff, just couldn't remember what I was going to try it on. ohwell But thanks for the suggestion and the link.
I must not have been holding my mouth right doing the search. Maybe I should try a different phrase in the quotes.
I'll try another search for the thread I first saw it in here.
[on edit]Found it with "open gear" HERE
It was leaf springs, which makes sense. Now I need to just write that down somewhere and not forget where I put the note. headscratch
Re: Search question [Re: klhansen] #1342501 Thu Jan 16 2020 10:47 PM
Achipmunk Offline
......since i had them apart I used the spring liners on my 52 panel. Drove it 7 years. Work good.
Pictures in my Photobucket
52 Chevy Panel
Re: Search question [Re: klhansen] #1342508 Fri Jan 17 2020 12:35 AM
Tiny Online
Global Mod
OK fellows, this is a digital tech forum.
Moderated by  Tiny, Volfandt
Powered by UBB.threads™ PHP Forum Software 7.7.3
