The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (reidy, 2 invisible), 185 guests, and 4 robots.
Forums50
Topics119,959
Posts960,710
Members43,525
Most Online1,229
Jan 21st, 2020
Image Posting Policy
10 bolt on my '50 3100
#1341954 Mon Jan 13 2020 08:56 PM
I have to admit I know next to nothing on gear ratio's. I've installed a 10 bolt, donor was an '81 Camaro. Yes, I could identify the rear end and then ask my question. I'm assuming that year of Camaro, non-positraction, came with one ratio as standard. Again, assuming that I'm correct, what should I expect for average driveability...obeying the speed limit most of the time?! This will be coupled to a 1995 Buick Roadmaster 350 LT1 with a 4L60E tranny.
Re: 10 bolt on my '50 3100
Rocket man #1341984 Mon Jan 13 2020 10:32 PM
Boltergeist
You probably have around a 3.73 ratio??? I run a 350 and a 305 with the 700R4, which is like the 4L60E, and with the overdrive they run smooth like a spinning top.....I'm running a 37 pickup, lightweight, and a 52 half ton panel. Go for it. You won't be disappointed.
Pictures in my Photobucket
52 Chevy Panel
Rocket man #1342108 Tue Jan 14 2020 02:16 PM
The standard rear gear ratio for a non-posi 10 bolt wold have been either 2:56-1 or 2:73-1. Check here for more info http://www.teufert.net/camaro/1981.htm
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Rocket man #1342176 Tue Jan 14 2020 08:26 PM
Boltergeist
thanks TUTS....I meant 2.73........I'm getting old!
52 Chevy Panel
Achipmunk #1342224 Wed Jan 15 2020 12:32 AM
I don't use the "O" word around my friends... grin
Craig
Q:"What yah runnin"
Rocket man #1342310 Wed Jan 15 2020 03:15 PM
What is the standard gear ratio for a 1995 Buick Roadmaster? Thats how you need to gear it, the 700R4 and 4L60E should have similar overdrives.
Moderated by  SWEET
