The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (47chevySC, marzach, J Lucas, 49choptop, Justhorsenround, 1 invisible), 340 guests, and 3 spiders.
Forums48
Topics117,080
Posts935,441
Members42,773
Most Online1,035
Jan 20th, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: Rusty Rod's 67 Suburban "the Kogai" [Re: Rusty Rod] #1341408 Fri Jan 10 2020 06:23 PM
Rusty Rod Offline OP
Moderator - The Electrical Bay and Rocky Mountain Bolters
January 1-9, 2020.
Slow going since Mrs. Rod has more "important" things for me to spend my time on.
I have been working on the dash area which is mostly cleaned up and repainted. I have reinstalled the wiper motor (and found out that it will NOT work if the switch is not grounded).
I ordered and received a repop speaker assembly and have it in the dash. I think I want to put some sort of cover over it to keep out dust and spilled coffee.
I picked a parts gauge panel off ebay, and have been studying how to put in some new gauges.
I would like to have an in dash tachometer. The tachometer option seems to be fairly rare (and pricey). I've checked out 4" tachs that would fit into the center bay of the bezel and a 2" tach that will fit into the extra gauge hole at the bottom next to the oil pressure gauge.
Another quality post.
Real Trucks Rattle
Re: Rusty Rod's 67 Suburban "the Kogai" [Re: Rusty Rod] #1341424 Fri Jan 10 2020 07:20 PM
Achipmunk Offline
Rusty Rod, I can truly tell you are having fun fun fun. Keep up the good work and keep us posted. You ARE gaining on it. smile
Pictures in my Photobucket
52 Chevy Panel
Re: Rusty Rod's 67 Suburban "the Kogai" [Re: Rusty Rod] #1342078 Tue Jan 14 2020 04:53 AM
January 10-13, 2020. Out with the Old and in with the New
I spent some more time messing with my dash gauge panel, I used a dremel tool to open the holes for the replacement gauges. They stick out the back a little bit, so i'll have to drill access holes in the cover plates. Easy money.
The new body mount kit came in the mail from Energy Suspension.
I finally got to pick up my new gas tank that ole boy down south mis-ordered. It came with everything but the big O-ring for the fuel level sender. I used a can of paint that has been on the shelf for a "while" to give it a bit more protection. I still need to acquire new rubber hoses for it though.
I jacked up the body enough to get the old remnants of body mount out and installed one side. I'll have to replace the two rear bolts, as they sent hex bolts instead of carraige bolts. I only had "issues" getting one front body bolt out but Mr. Impact Wrench made short work of it. Luckily there were only two body bolts that had nuts on them.. the rest were not replaced when they swapped out the body!
Real Trucks Rattle
Re: Rusty Rod's 67 Suburban "the Kogai" [Re: Rusty Rod] #1342952 Mon Jan 20 2020 03:50 PM
January 14-19, 2020.
I spent most of my available time in the garage cleaning parts and applying rust inhibitors. It took me three attempts to get the heater controls and the heater box to fit into the same space. I ended up bending the heater control a bit. I guess this explains why the back portion was loose.
I have another shipment of parts coming in from Classic Chevy soon. I'll be able to install the gas tank and run the engine with a real fuel supply.
Real Trucks Rattle
Re: Rusty Rod's 67 Suburban "the Kogai" [Re: Rusty Rod] #1342956 Mon Jan 20 2020 03:59 PM
Justhorsenround Online
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Mrs Rod is being very generous! thumbs_up
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Page 3 of 3 1 2 3
Moderated by  HandyAndy, John Milliman
Powered by UBB.threads™ PHP Forum Software 7.7.3
