The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (DougH6100, Nomad02, CDY, olezippi, GregBanf, Jeler, 1 invisible), 154 guests, and 3 robots.
Forums50
Topics121,046
Posts970,429
Members43,831
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 6 1 2 3 4 5 6
Re: 1937 216 rebuild
John Dlugos #1341908 Mon Jan 13 2020 05:18 PM
Thanks Dave that's what I wanted to hear.
Thanks for info Jerry.
Since the 39 short block is new old stock standard bore I'm thinking flat top aluminum standard pistons with a 42 head. This way I don't have to pay for a bore.
I like to do things right but I'm kinda cheap
What do you guys think, John
37 Chevy 1.5 ton
17 Dodge Brothers Roadster
23 Dodge Brothers Touring
23 Dodge Brothers Coupe
73 Plymouth Scamp 2 dr
John Dlugos #1341916 Mon Jan 13 2020 05:41 PM
Sounds like a good plan.
My Blog
John Dlugos #1341919 Mon Jan 13 2020 06:29 PM
Boltergeist
Aluminum 216 pistons are pretty expensive. People give me good condition std. bore 235 pistons just to get them out of their way when they rebuild their engines, and I recycle them into 216 engine buildups. That usually makes the cost of a rebore job a moot point- - - -especially since I've got a couple of Van Norman boring bars and a "retired old man" work schedule!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
John Dlugos #1341928 Mon Jan 13 2020 07:05 PM
i will run that by my engine guy but if I don't have a source for good used pistons from 235 isn't the cost for 216 and 235 pistons about the same?
37 Chevy 1.5 ton
John Dlugos #1341931 Mon Jan 13 2020 07:22 PM
Boltergeist
About the only source I'm aware of for aluminum 216 pistons is Egge Machine, and they think they're made of gold, not aluminum alloy! Original equipment 216 pistons were cast iron. Try an ad in the "parts wanted" forum- - - -somebody's probably got some good used 235 pistons left over from an engine job gathering dust on a shelf somewhere.
John Dlugos #1341948 Mon Jan 13 2020 08:45 PM
Just so you know, a standard bore 216 would need to be bored .062” over for a standard bore 235 pistons.
My Blog
John Dlugos #1341952 Mon Jan 13 2020 08:51 PM
Boltergeist
Most machinists bore any cylinder to the diameter of the piston that's going into the hole, and put the skirt clearance in with a hone to eliminate the machining marks. The finish bore would end up 3 9/16" for a 235 Std. piston, with about .0025-.003" skirt clearance- - - -3.0625" final diameter, with the clearance built into the piston skirt. To do it accurately most good machinists insist on having the pistons on hand before they start whittling on the block, and fit each piston individually.
John Dlugos #1341960 Mon Jan 13 2020 09:24 PM
Actually 3.5625 to be accurate Jerry.
My Blog
John Dlugos #1341963 Mon Jan 13 2020 09:27 PM
Also, before using any used aluminum pistons, look very close at the ring lands/grooves for wear.
My Blog
John Dlugos #1341980 Mon Jan 13 2020 10:03 PM
Maybe I missed something but I thought OP said he had an NOS shortblock. If that's true what's the need for boring and pistons at all. There's a lot to be said for a stock bore and pistons not to mention the stock size rotating assembly. Basically all he'd have to do is come up with a properly aligned oil pan, pump and have the head rebuilt. What am I missing? I've been on pain meds from a kidney stone removal so that's certainly possible. Drink more water!
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Moderated by  Woogeroo
