The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (D B Cooper, RBachman, RdsLessTaken, Greg C, Rabaut, HandyAndy), 179 guests, and 3 robots.
Forums50
Topics122,228
Posts980,558
Members44,189
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Brake Adjustment Guide
#1341397 Fri Jan 10 2020 05:38 PM
Unrepentant VW Lover
Brake Experts:
Just digitized a guide I made for myself to speed up the adjustment process on my (perfectly fine) Huck brakes. I put this diagram on a clipboard or taped it to the inner fender so I could refer to it as I was sitting infront of my brake assembly. Adjusting the wheel cylinders isn't so bad with the brake drum off (you can see how things move) but once you put the drum on, trying to remember all the geometry is hard, so I hand drew the original of this guide to help.
Hopefully, it makes sense if you have it in front of you while you are facing the front of the brake assembly. The wheel cylinders are all the same so it doesn't matter which side of the truck you are on (pass or driver). All "Left" and "Right" references are to you as you face the wheel cylinder (either exposed, or underneath the drum).
The backing plate is shown edgewise as you reach around from either side. So, to adjust out on the right side, you insert the lever high on the adjustment wheel, with the handle low. Pull up on the lever to adjust that side out. And so on for the others. Does this work?
Does this also apply to Bendix brakes?
Thanks for any input. I'm hoping to save people from aggravation and speed up their adjusting.
r/s
"Paul! Klaatu barada nikto. KLAATU BARADA NIKTO!!!!"
'49 Chevrolet 3804
Re: Brake Adjustment Guide
John Milliman #1341400 Fri Jan 10 2020 05:47 PM
They all are right hand threads. I picture the cylinder & which way to turn it.
This does not apply to Bendix Style brakes. They all adjust the same way. Self adjusting brakes are opposite of the manual adj. brakes.
George
[url=http://www.stovebolt.com/gallery/capito%20george%201956.html]
1972 Chevy c10 Cheyenne Super
John Milliman #1341454 Fri Jan 10 2020 10:14 PM
Thanks George -- So this only applies to the Huck brakes ... good to know.
'49 Chevrolet 3804
John Milliman #1341506 Sat Jan 11 2020 02:08 AM
Righty tighty, Lefty loosey, when viewing from the end of wheel cylinder.
Easy as pie, until I do it backwards every other time regardless of knowing this.
Maybe if we miniaturize your diagram and have it etched onto the lens' of my reading glasses...
John Milliman #1341507 Sat Jan 11 2020 02:13 AM
Boltergeist
...you just have to remember your turning the wheel...not the threaded bolt....or it will get confusing!
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.google.com/share/AF1...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
52 Chevy Panel [photos.app.goo.gl]
John Milliman #1341696 Sun Jan 12 2020 02:06 PM
A Slight variation ............ I painted a small white dot on the backing plate. It indicates the lever point for tightening the brakes. Indicates at a glance with out thinking which way to lever the adjuster
John Milliman #1341811 Sun Jan 12 2020 11:37 PM
Remember, bashing knuckles means tight.
Ed
John Milliman #1342271 Wed Jan 15 2020 06:11 AM
Really nice graphic John! I’ll print and use it during my upcoming brake overhaul.
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
John Milliman #1342280 Wed Jan 15 2020 12:06 PM
Thanks for the input, Chuck!!
'49 Chevrolet 3804
Moderated by  SWEET
