Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time. Look to see what's been cancelled or postponed.
Just digitized a guide I made for myself to speed up the adjustment process on my (perfectly fine) Huck brakes. I put this diagram on a clipboard or taped it to the inner fender so I could refer to it as I was sitting infront of my brake assembly. Adjusting the wheel cylinders isn't so bad with the brake drum off (you can see how things move) but once you put the drum on, trying to remember all the geometry is hard, so I hand drew the original of this guide to help.
Hopefully, it makes sense if you have it in front of you while you are facing the front of the brake assembly. The wheel cylinders are all the same so it doesn't matter which side of the truck you are on (pass or driver). All "Left" and "Right" references are to you as you face the wheel cylinder (either exposed, or underneath the drum).
The backing plate is shown edgewise as you reach around from either side. So, to adjust out on the right side, you insert the lever high on the adjustment wheel, with the handle low. Pull up on the lever to adjust that side out. And so on for the others. Does this work?
Does this also apply to Bendix brakes?
Thanks for any input. I'm hoping to save people from aggravation and speed up their adjusting.
r/s John
John "Gort! Klaatu barada nikto. KLAATU BARADA NIKTO!!!!"
They all are right hand threads. I picture the cylinder & which way to turn it. This does not apply to Bendix Style brakes. They all adjust the same way. Self adjusting brakes are opposite of the manual adj. brakes. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. [url=http://www.stovebolt.com/gallery/capito%20george%201956.html] 1972 Chevy c10 Cheyenne Super
Righty tighty, Lefty loosey, when viewing from the end of wheel cylinder. Easy as pie, until I do it backwards every other time regardless of knowing this. Maybe if we miniaturize your diagram and have it etched onto the lens' of my reading glasses...
A Slight variation ............ I painted a small white dot on the backing plate. It indicates the lever point for tightening the brakes. Indicates at a glance with out thinking which way to lever the adjuster
