The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (clrh2ofrank, BC59, 20Mercman, impalaken68, 1 invisible), 238 guests, and 3 robots.
Forums60
Topics122,987
Posts992,412
Members44,573
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 9 1 2 3 4 5 6 7 8 9
Testing Daytona Universal Carburetor UN2
#1341243 Thu Jan 09 2020 08:59 PM
Gabriel Sandoval
Greetings stovebolters. I recently looked up information on Stovebolt.com regarding the Daytona Universal Carbs, and it seems nobody had tried it out yet. I thought Id try it out and update everybody on this Carb.as I went along. So I decided to write to the company directly and ask them about their UN2 unit, and how it worked. The gentleman I was in contact with Mr. Ron Hewitt was very helpful and gave me allot of information regarding their carburetor. Ill put the detailed information he gave me later in this thread if anybody is interested. What stood out of what he wrote is that they've sold over 6000 units. Chevs of the 40's alone sells about 10-20 units per month. So I thought Id give their carb a try and inform everybody on my progress and results good or bad of this carb. Ill try to be as impartial as possible.
The test vehicle is my 1946 Chevy pickup. It has a 261 Chevy engine from I believe around 1958 (ill check on that later). Ive been running a Rochester Carburetor that was working great until a few months ago. The engine is nearly all stock. except for the 12v system with alternator. Its running regular points. When I first got it, It was giving me a consistent 12 M.P.G lately that's dropped to about 10 M.P.G I suppose mostly because for some reason ive been losing the fuel in the bowl (though I haven't confirmed this but will upon removal) and the need to crank the engine until fuel is delivered after it sits for a few days. I will set my points again, most likely at 18 thousandths. Ill also change the intake exhaust manifold to a nice painted one I have ready to go. Pictures of the installation coming soon. Heres what it looks like now.
Re: Trying Daytona Universal Carburetor UN2
Hotrod Lincoln #1341245 Thu Jan 09 2020 09:10 PM
Gabriel Sandoval
Was that his name? Coincidence I guess.
ClassicsR4Me #1341248 Thu Jan 09 2020 09:19 PM
Gabriel, your truck is a beauty. It looks great!. I would never remove my Carter but I'm interested in what you come up with.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #1341249 Thu Jan 09 2020 09:27 PM
Gabriel Sandoval
Thanks Mark, yeah I love my truck, its a blast to drive. I was told that the best Carburetor to run on these engines is the Zenith Carb. Ive heard that they are very expensive though. These Daytonas are supposed to be copies of those, that's one of the main reason I was interested in trying it, besides the fact that its a brand new Carburetor. We'll see how it runs with it and keep it posted.
ClassicsR4Me #1341251 Thu Jan 09 2020 09:36 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
The Daytona has been poo pooed here since it first became available. It will be interesting to see actual documented experience with it. If folks will keep it civil and forget the snide insulting comments thus allowing you to be as unbiased as possible. Try not to go on the defensive and just report what you find. You will have to develop a thick skin as I’m sure some will not adhere to my above advise. Good luck.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Justhorsenround #1341256 Thu Jan 09 2020 10:00 PM
Gabriel Sandoval
Thanks for the heads up. I personally like to keep things original also, but as carbs get older and they are constantly rebuilt, they lose a bit of their drivability. I can always go back to the Rochester, but its nice to try something new and see how it works. Im curious to see how the Daytona performs. Might like it, or might hate it, never know till you try it.
ClassicsR4Me #1341277 Fri Jan 10 2020 12:35 AM
Gabriel Sandoval
It looks like my Rochester was losing fuel somehow. It looks a bit too low in the bowl. Can someone tell me where the fuel leakage usually comes from on the Rochester? Side by side comparison of the Rochester next to the Daytona. Customizations ill have to perform. The fuel cable bracket needs to be flipped over and upside down, then have the bracket bent down 90 degrees. Another thing ill need to change is the distributor vacuum line. On the Rochester its towards the front of the fuel air mixture needle, on the Daytona its towards the rear. I will connect it by rubber vacuum line. Also, wont be able to use my original heavy duty air filter. Regular air filter should be ok.
ClassicsR4Me #1341279 Fri Jan 10 2020 12:38 AM
I don't think quality control is the problem, it's the idea that a few variants can be as close to the original mixture requirements as the many, many OEM carburetors. L6 engines of the same size will not require the same carb except by accident.
They may have developed the throttle disc size, venturi, jetting, vacuum setting, pump discharge, idle and transition hole sizes and locations, etc. on a specific engine, and will give good results... on that engine.
As your engine begins to differ from their model (displacement, CR, port size, cam timing, spark advance curve, valve area, overlap, rod ratio) the results will be worse - but perhaps tolerable.
Now, the 235 is an excellent model for this due to long use with very similar tune-up specs, so we certainly would like to hear results.
TIA
ClassicsR4Me #1341280 Fri Jan 10 2020 12:47 AM
Looks like the Chinese Zenith knockoff I purchased. I used the carb on a test engine (GMC 248) and it performed well.
SS396CV #1341317 Fri Jan 10 2020 04:00 AM
Gabriel Sandoval
This is what Mr. Hewitt wrote in regards to that point. "The base Daytona UN2 carburetor has been in constant production in South America since 1957". I believe they are made in Argentina. They have a 1 year warranty for manufacture defects.
Moderated by  Woogeroo
