The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (dirtball, kades51, glenns towing, Barnfind49, LAJones48, LexAdmn), 382 guests, and 3 spiders.
Forums48
Topics117,365
Posts938,471
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Chevy truck rears '55-'59 vs. '60-'66 #1340334 Fri Jan 03 2020 10:30 PM
John Leatherman Offline OP
Are there major differences between the '55-'59 half ton rears and the '60-'66 half ton rears? Brakes? Center section?
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340376 Sat Jan 04 2020 01:59 AM
Pre '68 Dave Offline
1955-62 use the same center section.
1955-59 had leaf springs, 1960 and later used coil springs.
My Blog
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340380 Sat Jan 04 2020 02:23 AM
Thanks. Sounds like I can probably use a rear up to '62 since I just want the center section and brakes/backing plates fir my '46.
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340387 Sat Jan 04 2020 03:04 AM
Fox Offline
I took a ‘62 3.90 gear set and bolted it right into my 1953 housing. I didn’t gain much ratio but did get open driveline. Gotta love GM LEGO pieces, hey?!
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340426 Sat Jan 04 2020 02:22 PM
Like Fox mentioned, a 1955-62 center section will bolt right in a 1940-54 truck axle housing.
The bendix brake swap is not so easy, easier to change the housing.
I will add that having Huck brakes on the back is not a bad thing.
My Blog
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340464 Sat Jan 04 2020 08:00 PM
texczech Offline
6 heaven
So an open driveline 55-62 1/2 ton third member will bolt into the earlier 54-49 axle housing? What about the axle shaft splines? Do they match the internal side gears from the 55+ third member?
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340470 Sat Jan 04 2020 09:18 PM
Same splines
My Blog
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340583 Sun Jan 05 2020 03:40 PM
texczech Offline
6 heaven
Wow, that makes an open driveline a simpler possibility. What are some transmission combinations? Will a 3 speed from the 55-66 model work with the 2 shifter arms & linkages fron the original style?
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340592 Sun Jan 05 2020 04:49 PM
rfs56trk Offline
You will need later bellhousing (48 up) to use a 55 and later transmission. I'm not sure what type side cover/linkage configuration a 46 has. The 55 transmission has a 4 bolt side cover. The 1/R shift fork has to be replaced on an AD truck to use the side cover on later trans. Yours may be similar. A 3 speed overdrive transmission would be a good option.
Fred
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340599 Sun Jan 05 2020 05:37 PM
To be accurate you would need a 1948-53 truck bellhousing to accept the later transmission and correct bellhousing mounts.
Since a 1946 is floor shift, you would need an aftermarket floor shifter for a 1955- trans.
My Blog
Page 1 of 2 1 2
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
