The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (David C., baldeagle, carbking, 49 3100, Gib70, 1 invisible), 171 guests, and 3 robots.
Forums50
Topics120,573
Posts966,440
Members43,701
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 250 engine swap into a 1959 apache
Tommy #1338684 Sun Dec 22 2019 12:50 PM
Tommy Offline OP
DL, no I still have the drum brakes. I think about them some times but the drums work fine just have to keep them adjusted. I'm old enough to know what it's like to drive a vehicle with out disc brakes.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1338697 Sun Dec 22 2019 03:23 PM
DLBrooks
OK, I am putting disc on mine as I already have setup a dual master cylinder and will add a proportioning valve. I will make my own caliper mouting bracket and will trace it after completion using 78 4wd 12" rotors and 72 calipers and hoses.
Tommy #1340439 Sat Jan 04 2020 03:38 PM
That 82 250 from a pickup is an intregal intake manifold cyl. head. It is not a good setup. You will need to get a different cyl. head with a separate manifolds.
Other then that I think it will be a good swap.
George
1956 Chevy 1/2-Ton Pickup
Tommy #1340567 Sun Jan 05 2020 01:05 PM
Tommy Offline OP
Yes George, I have an older 230 engine that I will use the head and manifolds from if I do the swap.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1340643 Mon Jan 06 2020 12:48 AM
Hi Tommy
I'm kinda a 250 Chevy - Six "Fan" . I really like 'em . With that being said - - - I'm running my 69 Nova with the "stock original 250 motor" ; and, had the P/G trans. Then, I went to the w/c T 5 (93 GMC S-15 version - tag # 1352 - 222 , with electric speedo) ; and, it fit very well into my Nova , using the stock (T 5) "input shaft" (14 spline input, with 21 teeth ) . here's my question ; with that 14 spline input shaft - - I used a 10 1/2" dia clutch disc in my set-up. - - - WHAT Is Your Input splines ?
Then, use a 'block mounted starter' for a 153 flywheel' ; 'a stock SBC Flywheel (153 teeth) ; and all stock clutch parts (pertaining to my car). I even used the Powerglide crossmember with a slight mod in the center (you may not need ,
because of your higher floor) .
If, your T 5 has " the 14 spline input shaft" - - - I have those 'Part numbers' .
If I can Help . . . jim
ps. - - I'm also running that "VSS electric speedo drive with my stock Mech. speedo dash . Works great !
Tommy #1340682 Mon Jan 06 2020 11:14 AM
Tommy Offline OP
Hey Jim, My world class t-5 was from a Camaro and had a fine spline input shaft. I don't remember the spline count maybe 21? Right now I have a s-10 trans in the truck with a 14 spline input shaft, used the original clutch disk from the 59 truck.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1341087 Wed Jan 08 2020 07:20 PM
Tommy
I also had the original S 15 clutch disc (was about 9 & 1/8" dia) but the disc I used was from 'SUMMIT : for a V 8 up-grade into an S-10 truck. Summit Part # ADD - 716104 (1" dia 'input shaft with 14 spline" - 10 1/2" dia).
The Camaro T 5 maybe like 26 spline count . . . just FYI.
Then, the "10 spline Jeep T 5 input shaft (that "Luntznuts65" ) talks about on his T5 Page . . Summit also has those (or on E-BAY) part # is 1351085008 R - - - I bought mine from Summit for $ 36.00. - - but, at that time did - not use it
Sometimes the Part Numbers are hard to FIND .
I'm just talking . . . jim
Tommy #1341088 Wed Jan 08 2020 07:37 PM
Tommy Offline OP
Jim yep I new the spline count was in the twenties, that trans is a world class out of a camaro. I did do the jeep input swap on another t-5 just haven't used it yet.
I also have one from an Astro van, with a 3.50 first gear. It has an input shaft that is the right length, no cutting, or grinding. The trans has the ford bolt pattern, so I had to get the bell housing off of the Astro van, it was on a 4.3 engine so it will bolt up to just about any chevy block after 1963.
Tommy
59 apache 1/2t
261 short stepside
Page 2 of 2 1 2
Moderated by  KCMongo
