The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 registered members (Andy4802, gsharum, olezippi, Jimmie D, bwilliams, 1 invisible), 390 guests, and 3 spiders.
Forums48
Topics117,364
Posts938,467
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Chevy truck rears '55-'59 vs. '60-'66 #1340334 Fri Jan 03 2020 10:30 PM
John Leatherman Offline OP
Are there major differences between the '55-'59 half ton rears and the '60-'66 half ton rears? Brakes? Center section?
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340376 Sat Jan 04 2020 01:59 AM
Pre '68 Dave Offline
1955-62 use the same center section.
1955-59 had leaf springs, 1960 and later used coil springs.
My Blog
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340380 Sat Jan 04 2020 02:23 AM
Thanks. Sounds like I can probably use a rear up to '62 since I just want the center section and brakes/backing plates fir my '46.
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340387 Sat Jan 04 2020 03:04 AM
Fox Offline
I took a ‘62 3.90 gear set and bolted it right into my 1953 housing. I didn’t gain much ratio but did get open driveline. Gotta love GM LEGO pieces, hey?!
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340426 Sat Jan 04 2020 02:22 PM
Like Fox mentioned, a 1955-62 center section will bolt right in a 1940-54 truck axle housing.
The bendix brake swap is not so easy, easier to change the housing.
I will add that having Huck brakes on the back is not a bad thing.
My Blog
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340464 Sat Jan 04 2020 08:00 PM
texczech Offline
6 heaven
So an open driveline 55-62 1/2 ton third member will bolt into the earlier 54-49 axle housing? What about the axle shaft splines? Do they match the internal side gears from the 55+ third member?
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340470 Sat Jan 04 2020 09:18 PM
Same splines
My Blog
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340583 Sun Jan 05 2020 03:40 PM
texczech Offline
6 heaven
Wow, that makes an open driveline a simpler possibility. What are some transmission combinations? Will a 3 speed from the 55-66 model work with the 2 shifter arms & linkages fron the original style?
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340592 Sun Jan 05 2020 04:49 PM
rfs56trk Offline
You will need later bellhousing (48 up) to use a 55 and later transmission. I'm not sure what type side cover/linkage configuration a 46 has. The 55 transmission has a 4 bolt side cover. The 1/R shift fork has to be replaced on an AD truck to use the side cover on later trans. Yours may be similar. A 3 speed overdrive transmission would be a good option.
Fred
Re: Chevy truck rears '55-'59 vs. '60-'66 [Re: John Leatherman] #1340599 Sun Jan 05 2020 05:37 PM
To be accurate you would need a 1948-53 truck bellhousing to accept the later transmission and correct bellhousing mounts.
Since a 1946 is floor shift, you would need an aftermarket floor shifter for a 1955- trans.
My Blog
Page 1 of 2 1 2
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
