The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 registered members (), 355 guests, and 1 spider.
Forums48
Topics117,308
Posts937,978
Members42,896
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1950 Side Cowl Vent #1340288 Fri Jan 03 2020 07:03 PM
3800GUY Offline OP
I have noticed on several pictures of these side vents that there are 2 springs that assist in the operation of the vent door. The vent door on my 1950 operates fine by hand from an inside lever, but the springs are long gone. Are these available new from any vendor? All answers appreciated. Thanks, Tom
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340290 Fri Jan 03 2020 07:38 PM
Achipmunk Offline
Tom, I don't think anyone makes them....Ace Hardware has a big selection of springs if you can get a photo of an original or just find one that works. Others will chime in...............and be sure to post an ad in the parts wanted forum. someone may have an extra/old cab.
Pictures in my Photobucket
52 Chevy Panel
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340295 Fri Jan 03 2020 07:58 PM
Spotbiltxo Offline
Never knew the vent door was spring assisted. Mine has none.
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340319 Fri Jan 03 2020 09:08 PM
Brad Allen Offline
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340330 Fri Jan 03 2020 10:14 PM
jorb Offline
Looks like you had to cut the replacement patch panel to save the original slot.
Are those louvers for air to pass-through ?
Re: 1950 Side Cowl Vent [Re: jorb] #1340337 Fri Jan 03 2020 10:47 PM
Wally / Montana Offline
Mine was floppy so I used a zip tie to keep the handle pulled back. No springs. My radio antenna is attached to the vent door on the outside.
28 Years of Daily Driving. Now with a '61 261, 848 head, Rochester Monojet carb, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340345 Fri Jan 03 2020 11:33 PM
Brad Allen Offline
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340346 Fri Jan 03 2020 11:36 PM
cmayna Offline
My green turd has no springs in it's side vent. Doesn't need them either.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340348 Fri Jan 03 2020 11:42 PM
glennj3 Offline
Now I found something else to check I never thought about. I don't think mine has any opening inside!
1953 Chevy 153A, 3/4 ton, 4 stick in the floor. Not original engine, has a strait 6 chevy engine with a Ford Carburetor.
Re: 1950 Side Cowl Vent [Re: 3800GUY] #1340354 Sat Jan 04 2020 12:06 AM
tclederman Offline
Boltergeist
3800GUY,
Do your doors have a single side glass, or a vent-window glass and a door glass?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Page 1 of 2 1 2
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
