The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (tomctomc, JW51, Johnny N, Pre '68 Dave, Greg_H, joe apple), 130 guests, and 3 robots.
Forums58
Topics122,567
Posts988,781
Members44,488
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 1982 S-10 Drum Brakes
coilover #1339870 Tue Dec 31 2019 07:06 PM
Apache1 Offline OP
Originally Posted by coilover
Some criticism aimed at all of us---myself included. We are so used to tapping computer keys we forget there are very detailed exploded drawings in old MOTORS's Manuals, (MOTOR'S and NOT Chiltons). This manual usually covered a seven year span so a 1982 to 1989 would have the drawing. We have a complete set from 1929 to the mid 70's and I ignore them until I get stuck on something; usually electrical or wiring. Something you might check out.
Yes indeed and I will be headed for a library later this week...thanks.
Apache1 #1339904 Tue Dec 31 2019 10:44 PM
Your photo shows a yellow spring and the related hardware that retains the actuator and the shoe to the backing plate. The back side of the retainer has a sleeve that goes through the actuator and the brake shoe. It may be possible that the hole in the shoe is too small or it has some sort of coating on it and could be binding and causing the tang to not set on the star wheel. My reference materials show a straight spring on some and others a beehive type design. The book I have calls it a return spring. I don't think it matters much except both are considerably smaller and weaker springs that would apply less pressure. My suggestion would be to do a test and remove the return spring and see where the actuator sets relative to the star.
Fred
Something I learned during my 50 years of working on this stuff. Don't throw anything away until you are finished and it works.
Apache1 #1339911 Tue Dec 31 2019 11:45 PM
Apache1 Offline OP
Good points and I need to place a very small amount of lube in that specific area for the reasons you mentioned. I will seek out some additional springs at the local parts house. I'm leaning heavily at this juncture to installing the one piece arm. I'm thinking the design engineers made this change for a reason. Time will tell.....
Apache1 #1339981 Wed Jan 01 2020 04:00 PM
First things first- - - -replace the worn adjusters so the teeth will be the right height. Then adjust the pawl to contact the star wheel by doing a little careful twisting of the pawl so it makes firm contact with the star wheel. I was working on automobiles in the late 1960's when self-adjusting brakes started being used, and I taught automotive classes at the high school and Vo-Tech school level for about 35 years. A few hundred of my students learned to do that, and it works very well.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Apache1 #1340244 Fri Jan 03 2020 01:54 PM
Crusty Old Sarge
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/14196/filename/Brakes 2.jpg[/img]I finally had a few minutes to dig through my Chilton manuals for the S-10. All the pictures of the drum brakes show the adjuster under the star wheel. I included the pictures and a break down of the drum assembly. I'm not sure if I am looking at the right year for your rear axle. I hope these help.
Brake assembly
Brakes exploded view
Craig
Come,Bleed or Blister somethings got to give!!!
59' Apache 31, 327 V8, Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
Apache1 #1340259 Fri Jan 03 2020 03:15 PM
Shop Clutterist
Hey Craig,
According to my Motor manual, GM used at least 3 different types of adjusters on the drum brakes. They were all based on the same general principle, but there were slight differences in the parts. You can see the difference in the actuator lever in your exploded diagram and the actuator lever in Apache1's picture.
Using S10 parts on a Camaro axle or vice versa may be the issue here.
Apache1: did you positively identify your axle before buying your new parts?
Gord
1954 1/2 ton 235 4 speed
Apache1 #1340286 Fri Jan 03 2020 06:41 PM
Apache1 Offline OP
Gord&Fran,
I got tripped up thinking all along that it was out of a Camaro because my front clip is....until the brake issue was exposed.
Correction : Its a GM 8.5 axle housing with a posi-unit. I was barely able to interpret the very shallow ID stamping's on the passenger side axle tube. Note: The axle tube measures 3.00 on the OD. Where and how it got a set of S-10 brakes is anyone's guess.
See Pic: I have the (ears) @ 5 and 7
Btw, I've ordered the (1) piece adjusters (w/star wheels & springs) just like the ones in the exploded views that TUTS 59 provided....should be here Monday. I'm hoping they will just fall into place. That (2) piece unit is just hokie IMHO.
I will certainly post the outcome.
Thanks again as always...everyone,
George
Apache1 #1340927 Tue Jan 07 2020 09:12 PM
Apache1 Offline OP
Installed the AC Delco OEM (1) piece adjuster arm w/o any issues. Pleased with the outcome...very, very positive contact and control of the star wheel to allow incremental adjustments.
All that is left...bleeding and getting a good pedal.
Another crisis avoided...thanks fellows yahoo
George
Apache1 #1340931 Tue Jan 07 2020 09:49 PM
Shop Clutterist
Good news. I keep a notebook and a computer file with details like part numbers, donor vehicles, sources etc. Should be helpful for the next owner.
Gord
Apache1 #1340940 Tue Jan 07 2020 10:38 PM
Crusty Old Sarge
Apache1, glad to hear you got it worked out, another set of eyes always seems to help.
Years ago my Wife gave me one of Stacy David's project build books. It was a great addition to my 59', I record everything from part numbers to hand built modifications. I go back to it all the time to refresh my memory (or lack of).
Craig
Page 2 of 2 1 2
Moderated by  SWEET
