The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (32vsnake, delky, 37 GC, D B Cooper, Hendog97, Gdads51), 107 guests, and 3 robots.
Forums60
Topics129,239
Posts1,048,097
Members46,231
Most Online1,229
Jan 21st, 2020
Page 1 of 4 1 2 3 4
#1339544 Sun Dec 29 2019 01:23 PM
Unrepentant VW Lover
For purposes of setting the charger correctly, are they "AGL" or "GEL" ?
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
'49 Chevrolet 3804
'73 IH 1310 Dump
'14 Ford E-350 4x4 (Quigley)
There is a specific charging procedure for recharging/charging a fully discharged 6v red top Optima AGM Battery. It is described on their website.
Recovery Option #2, on the right.
What type/model Optima battery are you referring to?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
John,
A gel battery design is typically a modification of the standard lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. Many gel batteries also use one-way valves in place of open vents, which help the normal internal gasses to recombine back into water in the battery, reducing gassing. Generally, gel batteries are less tolerant of high heat and are charged at lower power than traditional or AGM batteries. An OPTIMA battery is neither a gel battery nor a regular flooded battery. OPTIMA is a SPIRALCELL TECHNOLOGY AGM battery.
Or, just drive Charlie more!
One more thing, there are no Dumb questions on this site, Mr Milliman! We just look at the person whom asked the question and take it from there! wave
See ya soon, in beautiful Morrisville Pa.
Jim
Jim Schmidt.
Bucks County, Pa.
1953, 3804
Pix in Photobucket [s854.photobucket.com]
No such thing as a stupid question. smile
John, if you have a UPS on your computer stuff, they use gel batteries. But like posted above Optimas are not gel, but are AGM (Absorbent Glass Mat).
My charger has an AGM setting. I just use that for recharging my boat Optimas.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
6v Optima available from Advance Auto Parts, with a 20-25% off promotion (25% shows up on a pop-up menu).
Tim
Thanks for the input everyone -- I'll try Tim's Option No. 2 when I get a chance (which won't be any time soon).
Will Rogers
'49 Chevrolet 3804
'73 IH 1310 Dump
I had a dead 6v Optima that would not charge, using any type of charger (including a heavy-duty big-truck battery-charger at a friend's professional garage).
The technique on the Optima website (that I linked-to, above), got the battery working again.
That was at least 10 years ago.
Tim
Tim, Roger that. The hardest part about that trick is finding a second 6-volt battery ... that's charged ... and isn't on the other side of the county
Will Rogers
'49 Chevrolet 3804
'73 IH 1310 Dump
Page 1 of 4 1 2 3 4
Moderated by  Rusty Rod
