The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (EdPruss, fixite7, Fireman30, Cletus1950, carbking, 2 invisible), 150 guests, and 4 robots.
Forums60
Topics124,646
Posts1,006,078
Members44,991
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 4 1 2 3 4
Dumb Optima battery question ...
#1339544 Sun Dec 29 2019 01:23 PM
Unrepentant VW Lover
For purposes of setting the charger correctly, are they "AGL" or "GEL" ?
"Of all tyrannies a tyranny sincerely exercised for the good of its victims may be the most oppressive."
— C. S. Lewis
'49 Chevrolet 3804
Re: Dumb Optima battery question ...
John Milliman #1339545 Sun Dec 29 2019 01:27 PM
John Milliman #1339548 Sun Dec 29 2019 01:52 PM
Bubba
There is a specific charging procedure for recharging/charging a fully discharged 6v red top Optima AGM Battery. It is described on their website.
Recovery Option #2, on the right.
What type/model Optima battery are you referring to?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
John Milliman #1339572 Sun Dec 29 2019 03:55 PM
John,
A gel battery design is typically a modification of the standard lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. Many gel batteries also use one-way valves in place of open vents, which help the normal internal gasses to recombine back into water in the battery, reducing gassing. Generally, gel batteries are less tolerant of high heat and are charged at lower power than traditional or AGM batteries. An OPTIMA battery is neither a gel battery nor a regular flooded battery. OPTIMA is a SPIRALCELL TECHNOLOGY AGM battery.
Or, just drive Charlie more!
One more thing, there are no Dumb questions on this site, Mr Milliman! We just look at the person whom asked the question and take it from there! wave
See ya soon, in beautiful Morrisville Pa.
Jim
Jim Schmidt.
Bucks County, Pa.
1953 3800
Pix in Photobucket
John Milliman #1339586 Sun Dec 29 2019 06:20 PM
No such thing as a stupid question. smile
John Milliman #1339613 Sun Dec 29 2019 10:22 PM
John, if you have a UPS on your computer stuff, they use gel batteries. But like posted above Optimas are not gel, but are AGM (Absorbent Glass Mat).
My charger has an AGM setting. I just use that for recharging my boat Optimas.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
John Milliman #1339623 Mon Dec 30 2019 12:11 AM
Bubba
6v Optima available from Advance Auto Parts, with a 20-25% off promotion (25% shows up on a pop-up menu).
Tim
John Milliman #1339631 Mon Dec 30 2019 01:27 AM
Thanks for the input everyone -- I'll try Tim's Option No. 2 when I get a chance (which won't be any time soon).
— C. S. Lewis
'49 Chevrolet 3804
John Milliman #1339635 Mon Dec 30 2019 01:50 AM
Bubba
I had a dead 6v Optima that would not charge, using any type of charger (including a heavy-duty big-truck battery-charger at a friend's professional garage).
The technique on the Optima website (that I linked-to, above), got the battery working again.
That was at least 10 years ago.
Tim
John Milliman #1339839 Tue Dec 31 2019 12:48 PM
Tim, Roger that. The hardest part about that trick is finding a second 6-volt battery ... that's charged ... and isn't on the other side of the county
— C. S. Lewis
'49 Chevrolet 3804
Page 1 of 4 1 2 3 4
Moderated by  Rusty Rod
