The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 registered members (48jim1ton, DennisM, clarsen3100, Bicounty, ClassicsR4Me, 3 invisible), 356 guests, and 4 spiders.
Forums48
Topics117,478
Posts939,123
Members42,871
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Throw out bearing. #1339347 Fri Dec 27 2019 08:19 PM
WE b OLD Offline OP
I have 1954 1/2 ton with a t5 transmission. When sitting idle with it out of gear and the clutch out it has started making a slight grinding noise, is that the throwout bearing I am hearing??
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: Throw out bearing. [Re: WE b OLD] #1339360 Fri Dec 27 2019 10:09 PM
Tommy Offline
Ron,
May be the bearing on the input shaft.
Tommy
59 apache 1/2t
261 short stepside
Re: Throw out bearing. [Re: WE b OLD] #1339377 Fri Dec 27 2019 11:39 PM
WE b OLD Offline OP
Thanks. I am to take it to the shop that installed it after the first of the year.
2017 Buick Encore
Pix on Photobucket
Re: Throw out bearing. [Re: WE b OLD] #1339379 Fri Dec 27 2019 11:47 PM
2-Ton Offline
I agree, The throw out bearing will grind when the clutch is down if it is bad. You may even feel it thru the clutch pedal.
The pilot bearing will make noise when in neutral and the clutch out, if it is going bad.
Either way, I would Drop the tranny and replace both.
Don
"The Flag Pole"
More pix on Photobucket
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Re: Throw out bearing. [Re: WE b OLD] #1339380 Fri Dec 27 2019 11:59 PM
showkey Online
Bad pilot bearing makes its most noise when the clutch pedal is completely depressed and the clutch itself is completely disengaged.
Re: Throw out bearing. [Re: WE b OLD] #1339408 Sat Dec 28 2019 03:25 AM
Phak1 Offline
Jack of all Trades, Master of None
The throw out bearing can also make noise if the clutch is not adjusted properly. If the clutch petal does not have enough free play when the petal is fully released, the bearing will be resting up against the fingers spinning with the flywheel. If there is no pressure on the bearing, it can rattle making noise.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Throw out bearing. [Re: WE b OLD] #1339419 Sat Dec 28 2019 11:06 AM
WE b OLD Offline OP
The people that installed the transmission will check it out sometime next month. It is getting to the place that all they work on is automatics. I had it in before and they called the previous owner of the shop in to take a look at it. I delivered parts to them when I worked for Autozone and from time to time take them some gourmet donuts. wink I do this for all the shops that potentially will work on the truck.
2017 Buick Encore
Pix on Photobucket
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
