The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (coilover, 2ManyTrucks, 52Carl, clarsen3100, DennisM, dirtball), 315 guests, and 3 spiders.
Forums48
Topics117,294
Posts937,765
Members42,883
Most Online1,229
Jan 21st, 2020
Image Posting Policy
rocker to inner rear cab corner #1339306 Fri Dec 27 2019 02:58 PM
Mike Burns Offline OP
on a 53 half ton, does the rear of a new rocker panel typically butt up to the front of the inner cab corner. I understand that is approximately the case. I'm just trying to loose fit the lower cab panels, and am just curious to know if a reproduction rocker panel typically has to be trimmed at the inner cab corner, or if it typically just butts up to the edge, and welded there. I realize that everything must be fit up properly prior to any welding. I'm just trying to get some rough ideas here.
Re: rocker to inner rear cab corner [Re: Mike Burns] #1339355 Fri Dec 27 2019 09:27 PM
klhansen Offline
There was about a 1/2" lap joint between the original rocker panel and the inner cab corner. I haven't checked closely yet on my new parts, but I believe that the lap joint should be there. I've removed all remnants of the inner corner to the floor panel and the replacements have an indent where the flange on the floor goes.
The location of the rocker needs to match up on the front where the parking brake bracket connects to the floor pan with the one large hole and two smaller ones. I think that's the more critical location for the rocker. I'm going by the holes and notches in the rocker for the weatherstrip hold-down screws. But I notice that they don't match up perfectly on all holes/notches.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.7.3
