The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 members (53 green 1- ton, bhap, 49 3100, 3B, bartender, David C.), 124 guests, and 3 robots.
Forums47
Topics117,791
Posts942,557
Members43,043
Most Online1,229
Jan 21st, 2020
Image Posting Policy
3800 dually brakes improvement
#1339194 Thu Dec 26 2019 05:34 PM
Jefe 56 Offline OP
56 3800 dually, all original wheels.
Hi all!
If I understand correctly the rear drum brake shoes are not available anymore.
We have bled the brakes and topped up the fluid, and only moderate improvement. She stops, with a lot of force and a little planning ahead.
What parts should I have in hand when I get some (limited) time in a friend's hoist later this spring?
Prefer trying stock-like stuff before researching (front?) disc kits further.
-J
1956 3800 stake truck
Re: 3800 dually brakes improvement
Jefe 56 #1339195 Thu Dec 26 2019 06:24 PM
You can have shoes re-lined. You'll also need to remove the glaze from the drums. Beyond that, you can get a stock, frame rail mounted booster, or go with an aftermarket drum/drum booster/mastercylinder kit made for the half tons. Albeit for half ton, it's still better than non-boosted stock. For ease of installation, get a stock booster from a 2-2.5 ton.
Jefe 56 #1339245 Fri Dec 27 2019 12:49 AM
Boltergeist
The brake drums, not the shoes, are what's almost impossible to find. Unless the drums are terribly scored, don't do much machining on them. Relined shoes aren't that difficult to find, or if your shoes aren't damaged, they can be relined. Keep the brakes adjusted properly and unless you're running max gross weight you should be able to stop safely without power boost with good linings. Original equipment style Hydrovac boosters are available, at some NAPA stores, even.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Jefe 56 #1339264 Fri Dec 27 2019 03:20 AM
Jefe 56 Offline OP
Thanks so much y'all for getting me pointed in the right direction! This clarifies things quite a bit.
Jefe 56 #1339298 Fri Dec 27 2019 02:27 PM
I have a 51 1 Ton single wheel and it stops quickly with the original setup. Because I don't carry loads I added a proportioning valve to the rear brakes to tame them down a bit. I think there may be choices for the type of lining that they redo the shoes with these days. I think they have different coefficients of friction.
1951 1 Ton Completed
Jefe 56 #1339307 Fri Dec 27 2019 02:59 PM
To concur with Hotrod Lincoln, by removing the glaze, I was speaking of using a 60 grit sandpaper. To have them turned would probably put you beyond spec.
Jefe 56 #1339309 Fri Dec 27 2019 03:12 PM
Boltergeist
Another sneaky trick to get better performance from drums that aren't original diameter is to glue a piece of sandpaper like one for a body shop air file to the inside of a drum, and scuff the lining contour to the same arc as the drum. It eliminates the "wearing in" process that needs to happen when a standard-diameter lining works against an oversize drum. Use a water-soluble glue like original Elmer's, and getting the sandpaper off once the linings are fitted is a lot easier.
Moderated by  Grigg
