The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (55 SHAKER, 58n63, C10 - C90 Bill, Achipmunk, AWinLex, Chasz), 241 guests, and 4 robots.
Forums47
Topics117,639
Posts941,049
Members43,013
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Aussie GM 1946
#1339258 Fri Dec 27 2019 02:59 AM
Moderated
Hi Guys I have recently obtained a 1946 Chef truck dually, I am trying to find info on the rig by way of the GM ( Holden Tags ) I suspect the vehicle was assembled in Australia therefore has Australian Tags. Any info that could be provided would be great. I am looking at doing a full restoration on the truck with some modern touches. ie V8 independent front suspension. I have attached some shots of the truck as it is now.
Cheers and Thanks
MIck
Re: Aussie GM 1946
Mick 1975 #1339271 Fri Dec 27 2019 04:27 AM
3B Offline
Hy Mick 1975, welcome, it looks like you have the equivalent of a 1 1/2ton Canadian truck there, from your pictures I think the cap in the middle of the front hub is the screw in type with eight sides on it pictures are too far away to be sure. Your truck could be anywhere between a 1939 and a 1947. Post some more closer pictures and a picture of the cab interior/ dashboard, hope that helps.
Re: Aussie GM 1946
Mick 1975 #1339272 Fri Dec 27 2019 04:36 AM
Bobb, did the Canadian trucks use the Art Deco cab already in '39? U.S. trucks didn't start with that style till '41.
Rich
'47 Loadmaster
Life is like a roll of toilet paper--the closer you get to the end, the faster it goes!
Re: Aussie GM 1946
Mick 1975 #1339296 Fri Dec 27 2019 02:21 PM
That is a nice cool old truck. It looks like it served someone well for many years. We just love photos here, the more the better!
1951 1 Ton Completed
Re: Aussie GM 1946
Mick 1975 #1339301 Fri Dec 27 2019 02:45 PM
Cool!
1959 Apache 3100 Fleetside SWB (Shop Truck) (modified)
Re: Aussie GM 1946
Mick 1975 #1339311 Fri Dec 27 2019 03:20 PM
That wheel bolt pattern(5/10) has been used on many modern GMC trucks, so modern axles are readily available, at least in the 'states. However, modern tubeless wheels(22.5) are hard to find in in that bolt pattern, at least in the 'states. Those wheels became available from the factory with the advent of tubeless tires in the late '50's, frequently on farm trucks.
Tubeless wheels in 19.5 size are commonly found, however, tires that size look 'undernourished' in those front fenders. I can't tell from pictures if your front fenders are the larger 1.5 ton size or the slightly smaller 1 ton size.
Full width front fenders, that would house full width front axles p(I have two sets) are rare, on GMC trucks(I know your is a '41 to '47 Chevy body style, at least in the 'states, which might be useful.
Ed
Moderated by  69Cuda, Grigg
