The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Keep your restoration going
Keeping your resto going
A good bit of advice nestled in the FAQ page.
Don't
Irwin Arnstein working on his
1959 Chevy 1-Ton
Read the article.
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (Hotrod Lincoln, delky, MarkT, 1 invisible), 77 guests, and 5 robots.
Forums59
Topics128,524
Posts1,041,225
Members46,037
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1338980 Tue Dec 24 2019 04:03 PM
Phak1 Offline OP
AD Addict
I bought a set of used rockers off of fleaBay for my ‘59 235 and the shafts are excessively worn. I see that I can buy replacement shafts but I haven’t seen any where they list different years. Are the shafts from a ‘59 the same shaft as previous models or are the holes in the shaft aligned with the offset groove in the rocker?
Phil
Moderator, The Engine Shop & Interiors
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Phak1 #1338998 Tue Dec 24 2019 06:17 PM
Rocker Arm Shafts are the same for 1940 to 1962 Chevy 6 cylinder engines .
GM # 0.353 - GM # 3836138
There are two rocker shafts on ebay .
Go to ebay & in the search box type.............3836138
Llewellyn GM Obsolete
Northridge , CA.
phone : 818 - 363 - 5094
Llewellyn has ( 1 ) GM NOS rocker shaft in stock
Here's a PIC of NOS rocker shafts that I purchased back in 2007 .
https://i.postimg.cc/rFftcj5C/Rocker-Shafts.jpg
These are getting scarce in GM NOS .
PIC
https://i.postimg.cc/fWgQMjGc/235-Chevy-Rocker-Shafts-GMNOS.jpg
George
'54 3600
1954 3600
Phak1 #1339076 Wed Dec 25 2019 02:40 AM
Here is a rocker arm rebuilding service that may be helpful. http://www.rockerarms.com/pages/gm.html
Phak1 #1339083 Wed Dec 25 2019 04:47 AM
I have used them for rocker arm rebuilding and they are excellent. Not inexpensive but when they are done with them, they are right on the money. No wobbling, oil leakage, nice new adjusters.
Mike
Phak1 #1339094 Wed Dec 25 2019 12:28 PM
Phak1 Offline OP
AD Addict
Thanks for all the suggestions. The rockers seems to be in good shape so all I want to replace is the shafts. My concern was the shafts being all the same thru the years. I checked the existing shaft and the holes in the shaft don’t align with the offset grooves in the rockers, so I want to make sure that is correct of a ‘59 235 before I invest more money into the assembly.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1339112 Wed Dec 25 2019 02:52 PM
The 1959-62 rocker grooves will not line up with the holes in the shafts.
This is the way Chevrolet restricted the flow.
My Blog [chev235guy.blogspot.com]
Phak1 #1339113 Wed Dec 25 2019 02:55 PM
Phak1 Offline OP
AD Addict
Thank’s that is the answer I was looking for!
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1339131 Wed Dec 25 2019 07:03 PM
It’s not that the rockers are in good shape, is the clearance between the shaft and the rocker. It’s important on the 59-62 version because if it’s a little out of specification, the oil pressure bleeds off around the rocker and because the 59-62 rocker has the off set groove, if the pressure is bleeding off around the rocker then the rocker does not get sufficient oil. Just check it carefully.
Mike
Phak1 #1339183 Thu Dec 26 2019 03:36 PM
Phak1 Offline OP
AD Addict
I’ll have to check the clearances but when I removed the rockers from the shaft, every place the shaft wasn’t worn, it tightened up nicely. Do you know what the clearances should be?
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1339185 Thu Dec 26 2019 03:42 PM
I have a set of new shafts and rockers under the bench, when I go out there today I'll try and run some clearances
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Page 1 of 2 1 2
