The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 registered members (BC59, carbking, David C., EdPruss, 2 invisible), 232 guests, and 4 spiders.
Forums48
Topics117,347
Posts938,274
Members42,909
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
261 #1338909 Tue Dec 24 2019 01:10 AM
Tony292 Online OP
I bought a 261 and SM420 today. I’m trying to figure out what year the 261 is. The casting numbers are pictured below. Any help deciphering is greatly appreciated.
Re: 261 [Re: Tony292] #1338919 Tue Dec 24 2019 02:00 AM
Dragsix Offline
The head is a later 261, 56-62 head with an 86.2 cc combustion chamber. If you remove the valve cover, the casting date will be right there and you can pin it down even further.
Mike
Re: 261 [Re: Tony292] #1338921 Tue Dec 24 2019 02:52 AM
Tommy Offline
3759365 is a 1959 block.
Tommy
59 apache 1/2t
261 short stepside
Re: 261 [Re: Tony292] #1338951 Tue Dec 24 2019 12:55 PM
John Milliman Offline
Hey look! It's a ...
If you show us the other casting numbers on the block (below and aft of the distributor pad), we can tell you the exact year and month the block was cast. Here's an example
'49 Chevrolet 3804
Re: 261 [Re: Tony292] #1338957 Tue Dec 24 2019 02:06 PM
tclederman Offline
Boltergeist
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 261 [Re: John Milliman] #1338995 Tue Dec 24 2019 05:51 PM
Tony292 Online OP
I’ll have to remove the starter to see that number there’s a lot of crud in that area.
Re: 261 [Re: Tony292] #1339036 Tue Dec 24 2019 09:14 PM
Tony292 Online OP
Did some more scraping and found k68 at the starter, is this November 6, 1958?
Re: 261 [Re: Tony292] #1339038 Tue Dec 24 2019 09:28 PM
tclederman Offline
Boltergeist
Yes, I think.
Wait to hear from others.
Tim
Re: 261 [Re: Tony292] #1339084 Wed Dec 25 2019 04:56 AM
Dragsix Offline
I forget now if they skipped the letter “I”. If so then it would be October 58. Either way it’s a block for the 59 model year.
Mike
Re: 261 [Re: Dragsix] #1339162 Thu Dec 26 2019 01:47 AM
Mike B Offline
Good question, I know they used "I" (eye) on the chassis serial numbers for September, I can't confirm if they used "I" on the engine casting date codes... but something in my old memory is saying they didnt...
Mike B smile
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
