The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (Apache1, dschmit, Hookalatch, Jimmie D, 2 invisible), 389 guests, and 3 spiders.
Forums48
Topics117,366
Posts938,487
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1937 SD Stakebody Restoration #1338685 Sun Dec 22 2019 12:51 PM
John Dlugos Offline OP
Starting a restoration of this truck after a 8 year break. Newbie to site so I don't think I can post pictures. Truck was parked on dirt floor barn since 1960 and has some rust pitting on rims, brake drums, etc. Fairly new to restoration work so tips and advice appreciated. Past restoration projects 1917 Dodge Brothers Roadster and 68 MG Midget. This is my first stovebolt build. I'll try to address things on at a time.
Truck has been disassembled and stored undercover. Frame has been sand blasted and epoxy primed. New spring pins and shackle bolts installed.
Disassembled transmission yesterday and started cleaning. Everything shifted ok but stiff before disassembly. No rust and everything coated in very thick tar like grease.Gears and bearing seem ok.
Anything I should be looking at in transmission before reassembly?
37 Chevy 1.5 ton
23 Dodge Brothers Touring
23 Dodge Brothers Coupe
73 Plymouth Scamp 2 dr
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1338730 Sun Dec 22 2019 09:02 PM
Wayne67vert Offline
Yea, another stake body truck on the stovebolt.
You are lucky to be able to restore your driveline. Mine was full of water and locked up tight.
I'll be following your progress.
Wayne
1938 1-Ton Farm Truck
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1338735 Sun Dec 22 2019 09:53 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
John, read the photo instructions in the left margin of every page. Give it a try. I don’t believe you are restricted from photos . But, I’ve been wrong before.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1338739 Sun Dec 22 2019 10:02 PM
Rusty Rod Offline
Moderator - The Electrical Bay and Rocky Mountain Bolters
Welcome to the 'bolt. There is a welcome forum that you can check into as well. have fun.
Another quality post.
Real Trucks Rattle
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1338746 Sun Dec 22 2019 10:53 PM
I thought I had to post 5 times before I could post pics. Didn't work on truck today. Hopefully tomorrow back to transmission.
37 Chevy 1.5 ton
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1338820 Mon Dec 23 2019 03:05 PM
Lightholder's Dad Offline
John,
Regarding the transmission, if the gears and bearings look good, you have a great start. That tranny (GTK-134) has no synchros so if the gear teeth are not obviously worn that is a good sign that it was used by someone who knew how to shift. Check the external case for broken mounting ears (the two at the top). While I am thinking about mounting the tranny, the bottom two bolts mount into the case so be sure to use sealant on the threads on assembly or you will end up with a slow drip.
The bosses cast into the case to mount the parking brake and pedal assembly also need to be examined. They are tapped for the mounting bolts but bottom out. If you use too long of bolts you will break off the bosses. So be sure someone else has not broken them and be sure your mounting bolts are not overly long.
Get your self an repair manual or look up on line (Old Online Chevy Manual, Keith Hardy's site). The only measurement necessary to reassemble is the gap between the cluster gear and case (0.015 to 0.045 inch, I think going on memory). If you decide to disassemble the shift tower, you can put sealant on the ends of the shift rails, another place these trannys leak oil.
Good luck and let us know how it is going,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: 1937 SD Stakebody Restoration [Re: Lightholder's Dad] #1338949 Tue Dec 24 2019 11:58 AM
Thanks for the info Kent. Will look at all suggestions a was hopefully today and post.
Manuals I have
Master parts list 29-47 and 29-48
Motors truck manual 1936-42
Happy Holidays, John
37 Chevy 1.5 ton
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1339098 Wed Dec 25 2019 01:17 PM
Here's some pic I hope
37 Chevy 1.5 ton
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1339099 Wed Dec 25 2019 01:18 PM
Going to work on drive line first so I will post progress there
37 Chevy 1.5 ton
Re: 1937 SD Stakebody Restoration [Re: John Dlugos] #1340225 Fri Jan 03 2020 10:53 AM
Finished transmission yesterday. Started rear end
37 Chevy 1.5 ton
Page 1 of 2 1 2
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
