The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (5 Window 9434, 55 SHAKER, den-den, carbking, 2 invisible), 249 guests, and 3 robots.
Forums50
Topics118,966
Posts952,251
Members43,300
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Speedo bullet
#1337858 Mon Dec 16 2019 03:03 PM
Saluki Offline OP
Has anyone adapted a speedometer cable bullet to an SM 420 tranny?
Thanks!
Re: Speedo bullet
Saluki #1337876 Mon Dec 16 2019 04:35 PM
ace skiver
Sorry about my ignorance, Saluki, but what is the "cable bullet"
Maybe you are referring to one of the "speedometer gears"?
"Speedometer gears include both a drive gear and a driven gear. The drive gear is located on the transmission's output shaft. The driven gear is positioned in a removable housing that is typically located in the transmission's tailhousing." (from TCXI automotive)?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Speedo bullet
Saluki #1337878 Mon Dec 16 2019 04:45 PM
ace skiver
I think I now know what the "bullet" is, Saluki (I did a Google search).
I only know Stovebolt gears - I think the "bullet" is an integral part on one of the original gears?
I think that you need a gear set (drive & driven) that matches your drive-train gear ratio (and your transmission attachment hole). Someone will correct/clarify this, I hope.
Tim
Re: Speedo bullet
Saluki #1337880 Mon Dec 16 2019 05:12 PM
Saluki Offline OP
The bullet is the adapter part that goes into the transmission housing that you hook the speedometer cable into.
Sorry I was not clear. It is a newer version that holds the driven gear. I also saw on eBay (I think) an SM 420 driven gear housing that appeared to have a plastic gear instead of the old metal gear.
IF that is possible I could replace the drive gear and driven gear. I currently have a 4 tooth drive gear and a 13 tooth driven gear that is a bit too slow. So I either change the gears or get an adapter to speed it up.
Re: Speedo bullet
Saluki #1337889 Mon Dec 16 2019 07:05 PM
Shop Clutterist
Earlier discussion on this: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=921081
I'm interested in this subject. I have a piece of paper with the speedometer reading to the actual speed written on it; not convenient but it works.
Gord
1954 1/2 ton 235 4 speed
Re: Speedo bullet
Saluki #1337895 Mon Dec 16 2019 07:55 PM
Saluki Offline OP
I have been using a GPS and I do understand the easiest thing to do is get a ratio adapter. I was just curious if anyone knew of a modification that I might also use.
With the number of 420 trannys out there I thought there might be another option.
Thanks for the link Gord&Fran, I also have a 54 1/2 ton.
If I knew what plastic gear would fit that old adapter, I would also change the drive gear. I could put in an 8 tooth drive gear and a 22 tooth driven gear.
Re: Speedo bullet
Saluki #1337911 Mon Dec 16 2019 08:59 PM
Shop Clutterist
There seems to be lots of gears for automatic transmissions and the 4 speeds found in muscle cars. But we have the SM420...
I'm still not settled on the ring and pinion gears in our truck. We might make a change there so I'm not too anxious to get the speedometer reading corrected now. Plus, our speed limits are in Km/h so I'm kind of used to doing conversions in my head.
Gord
Re: Speedo bullet
Gord&Fran #1338674 Sun Dec 22 2019 05:56 AM
I don't know if they are all the same but my speedometer is adjustable. Kind of trial and error but I was able to dial mine in pretty well.
Moderated by  SWEET
