The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 registered members (3B, ClassicsR4Me, 55 SHAKER, 51sub, bztguy, '50@7703', 1 invisible), 371 guests, and 4 spiders.
Forums48
Topics117,495
Posts939,317
Members42,881
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Removing Distributor Gear [Re: ClassicsR4Me] #1338598 Sat Dec 21 2019 06:01 PM
Pre '68 Dave Offline
Never seen a failure with one spring pin.
It's the way most manufacturers do and have done it.
My Blog
Re: Removing Distributor Gear [Re: ClassicsR4Me] #1338611 Sat Dec 21 2019 07:36 PM
Phak1 Offline
Jack of all Trades, Master of None
If you think about it, the most likely reason for the pin to shear is a total failure of the oil pump. In that case I personally would prefer the pin to shear than destroy the tang driving the oil pump or distributor.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Removing Distributor Gear [Re: ClassicsR4Me] #1338643 Sat Dec 21 2019 11:54 PM
Good point!
My Blog
Re: Removing Distributor Gear [Re: ClassicsR4Me] #1338646 Sun Dec 22 2019 12:32 AM
Hotrod Lincoln Online
Boltergeist
I have seen spring pin failures on a distributor drive, but not on a Chevy engine. The same Ford 300 engine sheared a spring pin twice within a couple of months. After the second failure, I pulled the oil pan and found that the sump had a lot of debris in it from a failing timing gear. The teeth had a plastic coating on them that was breaking down into granules about the size of a match head. The oil pump pickup screen also had holes in the mesh strainer big enough for those pieces to get sucked into the oil pump.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Removing Distributor Gear [Re: ClassicsR4Me] #1338676 Sun Dec 22 2019 06:04 AM
Dragsix Offline
I have never had a roll pin failure with a single pin. I safety wire my personal distributor rebuilds primarily because Jim Linder (gmc bubba) did that to one of mine before he stopped doing them so belts and suspenders for me.
On the other hand, my vertex magneto for 235/261 uses a single roll pin. I purchased the vertex as a rebuilt unit from vertex back in the early 80s and have run it up to 6000 rpm no issues with the pin. So I do think a single pin is no problem, that and I am with the others, rather a pin shear then have the tang get taken out on the vertex.
Mike
Re: Removing Distributor Gear [Re: ClassicsR4Me] #1338757 Mon Dec 23 2019 12:36 AM
1Ton_tommy Offline
For what it's worth, perhaps not much, but I once had a 57 Pontiac with factory Rochester Fuel injection. The injection pump was driven off the distributor. The distributor gear was pinned to the shaft with a roll pin -- which sheared more than once. I went back to the dual four barrel setup.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Page 2 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
