The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (lynngrove, BC59, carbking, David C., EdPruss, Brad Allen), 366 guests, and 4 spiders.
Forums48
Topics117,347
Posts938,274
Members42,909
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1949 3600 Slanting a radiator. #1335756 Fri Nov 29 2019 05:54 PM
1949hodag Offline OP
Moderated
I am wanting to know what you all did to slant your radiator in a 3600 or 3100. I am doing a 3600 on an S10 frame. But I have the steering gearbox in the way, so it would sit to high. I am looking for input to do this right the first time. Thanks. Pictures would be great, they speak volumes.
Re: 1949 3600 Slanting a radiator. [Re: 1949hodag] #1335772 Fri Nov 29 2019 09:40 PM
bartamos Offline
Truck Whisperer
Doing it right is......no slant. But you may mean something different by "slant" than I think. I also don't know if you have a mechanical fan or electric.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: 1949 3600 Slanting a radiator. [Re: 1949hodag] #1335777 Fri Nov 29 2019 10:42 PM
52Carl Offline
Pics. We need pics.
Re: 1949 3600 Slanting a radiator. [Re: 1949hodag] #1335791 Sat Nov 30 2019 12:46 AM
bartamos Offline
Truck Whisperer
Not sure I want to see a stovebolt on a S10 anymore. I'll hide my eyes if pics are posted.
Re: 1949 3600 Slanting a radiator. [Re: 1949hodag] #1335794 Sat Nov 30 2019 01:01 AM
panic Offline
I assume you mean lean the top tank backward? Pulling the left side back also works if that helps.
You have to mask off the 2 triangles of open space created between the radiator bulkhead and the new core position. Depending on the design, they can have the rad side mtg. holes on both sides. Seal them with gaskets, I use old inner tube sections.
Sealing the top tank to the hood will be worse, depends on what the inside of the hood looks like over the new tank position. Whatever: all air reaching the core must pass through it, not around it.
The shroud will be similar with reverse angle except of course triangular sides with the opening "normal" to the fan.
I make dummies out of "shirt" cardboard to get the sizes, then 18 gauge galvanized. Pop rivets are helpful to join to either rad or bulkhead. If the angle is very shallow, the triangles can have long slots to drop the rad down into place, but this usually requires the hood to come wayyy up (or off) to work.
Re: 1949 3600 Slanting a radiator. [Re: 1949hodag] #1335835 Sat Nov 30 2019 11:12 AM
coilover Offline
There is plenty of room to raise the radiator with no hood contact problem. As the picture shows the radiator is only raised a bit over two inches. I prefer a smaller fan blade with a GOOD shroud but many go with an electric puller fan since there is bukoos of room even with a long water pump. A regular fan blade will hit the lower hose nipple or wrongly designed auto trans cooler lines so a custom shroud is necessary.
[img]https://i.postimg.cc/FkFJr3vj/S10-051.jpg[/img]
[img]https://i.postimg.cc/Pp9BhzY7/S10-052.jpg[/img]
Evan
Re: 1949 3600 Slanting a radiator. [Re: 1949hodag] #1337830 Mon Dec 16 2019 08:34 AM
miraclepieco Offline
Ah, the old pesky radiator/steering box clearance issue on an S10 conversion. By far most guys fabricate a new radiator mount above the steering box and use a smaller 19x22 aluminum radiator from Summit Racing. They mount it vertical - no slant back.
1951 Chevy Panel Truck
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.7.3
