The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 registered members (55 SHAKER, carryall jerry, Drew54, Bill Trotter, 3 invisible), 378 guests, and 3 spiders.
Forums48
Topics117,294
Posts937,758
Members42,883
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Does this look right? [Re: Brad Allen] #1337572 Sat Dec 14 2019 12:25 AM
Joel1948 Offline OP
That photo makes sense. The bar was meant to follow the recessed part in the door. Looks like whoever makes these replacement Chevy/GMC Pickup Door Front Relay Remote Controls, didn't know they were changed in 1950. I'll make them work.
Thanks Brad,
Re: Does this look right? [Re: Joel1948] #1337697 Sun Dec 15 2019 01:34 AM
52Carl Offline
The change was made by GM to change to pull to open, rather than push to open. I am guessing that it was a safety measure, It would be relatively easy to accidentally push the handle forward with a wayward knee, causing the door to fly open.
There is no reason why an earlier push-to-open door can't be converted by installing the later pull-to-open mechanism. The doors are all the same in terms of attaching either one.
Maybe the reason that the push-to-open mechanisms are not available from the aftermarket is because they are a bad idea in regards to safety.
Carl
Re: Does this look right? [Re: Joel1948] #1337783 Mon Dec 16 2019 12:43 AM
Joel1948 Offline OP
I ran across a video of a guy installing an Altman EZ latch. I went to the website at Trique mfg and found their latch for the AD trucks is for 47- 51 and 52-54. Must have been some significant changes. I have a spare door from another 48 and I found it is 1/4" shorter in width than the ones on my 48. Might explain why they don't fit although it's hard to imagine why somebody replaced both doors at some point.
Re: Does this look right? [Re: Joel1948] #1337827 Mon Dec 16 2019 08:06 AM
miraclepieco Offline
47 and early 48 had the bar follow the recess. After that Chevy changed it to angled like yours to reverse the handle pull direction as 52Carl said. Reproduction units only come in the angled configuration. If you want them horizontal you'll have to find some original 47 relays or do what I did: modify 1965 relays:
1951 Chevy Panel Truck
Re: Does this look right? [Re: Joel1948] #1337988 Tue Dec 17 2019 12:49 AM
52Carl Offline
The change made between 47-51 and 52-54 had to do with the way the latch attaches to the door with the advent of push button exterior handle and its redesigned latch.
Page 2 of 2 1 2
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
