The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (bowtietim, Fox), 261 guests, and 3 robots.
Forums50
Topics120,011
Posts961,180
Members43,538
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
1964 Chevrolet C10 4x4?
#1337644 Sat Dec 14 2019 05:26 PM
Surfer Offline OP
Is their such thing as a 1964 Chevrolet C10 4x4? The truck is registered as a C10 and is 4WD is that possible? The vin On frame and cab match and their is no sign of modifications. Is this possible? Or a NAPCO?
Robert Ariasa
Re: 1964 Chevrolet C10 4x4?
Surfer #1337646 Sat Dec 14 2019 05:43 PM
ace skiver
Hello, Robert,
That information should-be/might-be available somewhere in the 1964 Chevrolet Truck Specifications Manual.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Surfer #1337649 Sat Dec 14 2019 05:56 PM
I think it should be either a CK10 or a K10. someone correct me if I'm wrong.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos!
Surfer #1337657 Sat Dec 14 2019 06:52 PM
whats the VIN on the frame?
Is there a spec sticker inside of glove box door?
How is the vin tag on driver door fastened? Could very easily been moved.
I may be completely naive but Cs were 2WD and Ks were factory 4WD and the VIN will tell the story.
HB
1966 Chevrolet K-10
Flappy Fenders
More pictures on Photobucket
1962 Chevrolet C10
Surfer #1337659 Sat Dec 14 2019 07:24 PM
That link that Tim posted tells the story. If it's a factory 4x4, the 2nd digit in the VIN will be K. If 2WD it will be C.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
J Lucas #1337673 Sat Dec 14 2019 10:46 PM
Surfer Offline OP
Thanks for the info tclederman
Robert Ariasa
Hambone #1337674 Sat Dec 14 2019 10:48 PM
Surfer Offline OP
Both the vin on the cab and on the frame are the same
Only C
Robert Ariasa
Surfer #1337677 Sat Dec 14 2019 11:03 PM
ace skiver
What is/are your "vins"?
And, where did you find them?
There was no standardized 17 digit VIN in 1964.
Tim
Surfer #1337683 Sat Dec 14 2019 11:41 PM
Sorry Tim. That page in your link indicated that it was a "Serial Number". I guess I'm the one that used the term VIN.
on edit: Wait, it was Hambone that first used VIN in this thread. I'm off the hook. wink
on edit again: Nope, it was the OP who first used vin. I'm off the hook again. grin
Surfer #1337693 Sun Dec 15 2019 12:57 AM
I will take that hit. But if the number on the frame has a "c" it was delivered as a 2WD. 4WD added later. I think you will find bolted on suspension brackets and other evidence of changes.
If you care to throw some pictures up of the suspension, front axle and transfer case and frame number, I suspect we might be able to derive some history.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Page 1 of 3 1 2 3
Moderated by  Hambone
