The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (SavannahDog), 118 guests, and 3 robots.
Forums60
Topics125,051
Posts1,009,308
Members45,127
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'62 C10 Transmission High Hump Needed
#1335452 Wed Nov 27 2019 04:14 PM
DougR Offline OP
Greetings!
Just replaced the column shift in my '62 to a floor shift. However, my transmission hump is too low. I need the high hump pan to accommodate a 3 speed floor shift. I've been searching on line but have yet to find what I think I need. I'm sure several of you guys have been through this. Any suggestions?
Thanks in advance and Happy Thanksgiving!
Doug Robertson
drr20175@gmail.com
1962 C10 shortbed
Re: '62 C10 Transmission High Hump Needed
DougR #1337655 Sat Dec 14 2019 06:39 PM
I got lucky when I found mine in an old junk yard about 13 - 14 years ago. There is a section of the firewall that you will need as well. Once you look at that area in the firewall, it will be obvious where to cut the spot welds and pull the piece out.
The rear part of the High Hump is a direct bolt in, but the front needs the matching piece that is welded onto the firewall.
The previous owner had swapped out the 3 Speed for the SM420 4 Speed, but did not change the tranny tunnel. They just bent a piece of sheet tin over the area and screwed it down. Ugly solution! I had to fix that.
Moderated by  Hambone
