The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (66flea, Lugnutz, Hog Wild, Lightholder's Dad, frogfarmer, Harold41), 127 guests, and 3 robots.
Forums50
Topics119,459
Posts956,463
Members43,405
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface
posey #1337310 Wed Dec 11 2019 07:24 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
posey #1337341 Thu Dec 12 2019 01:54 AM
As far as size goes, measure the diameter of the area where the seal will ride. next look at the manufacturer's listing. Each speedi sleeve has a range of diameters it will service. We are talking a few thousands of an inch here. I think this is the link you want. Speedi Sleeve Listing
1951 1 Ton Completed
posey #1337397 Thu Dec 12 2019 02:28 PM
Not meaning to hijack this thread, but I wish there was a type of speedi sleeve for the axle itself in the location where it contacts the bearings. My 1941 axles are slightly pitted at those points and that is less than desirable.
truckernix #1337406 Thu Dec 12 2019 04:26 PM
posey Offline OP
Thanks for the help, what I was looking for,
posey #1337423 Thu Dec 12 2019 06:59 PM
posey Offline OP
That is what I am looking for but for the sealing surface of the oil seal, not the bearings
posey #1337425 Thu Dec 12 2019 07:08 PM
Boltergeist
Tom, I've tinkered with the idea of machining the axle shaft down 1/8" or possibly a little more and fabricating a sleeve to press-fit on, then machining and grinding the OD of the sleeve back to OEM diameter. Some alloy like oil hardening drill rod, for instance, could be machined for a close fit, then heated and expanded for installation purposes with a torch, and shrink-fitted and hardened at the same time by quenching in an oil bath. No heating of the axle would be required. Once the sleeve was in place a tool post grinder in a lathe would be needed to establish the finish diameter. That process would also replace the seal surface with smooth metal the right diameter.
The cost would be considerable unless someone had his own machining equipment, however.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
posey #1337428 Thu Dec 12 2019 07:58 PM
Makes sense - was wondering if that could be done. Finding a decent set of axles is more than difficult...
posey #1337457 Fri Dec 13 2019 01:32 AM
Boltergeist
If somebody could write a CNC program to turn out repair sleeves by the dozen, the installation machining and finish-grinding process wouldn't be as labor intensive as making the sleeves one or two at a time.
posey #1337463 Fri Dec 13 2019 02:15 AM
Tom , there is a bearing sleeve for your job .
I have several axles here with this done . The axle is turned down to the correct size and the bearing # IR1502 installed . I remember buying the sleeve a couple of times , once here in New Zealand , the other online from USA .
Check out your local bearing suppliers .
posey #1337490 Fri Dec 13 2019 12:20 PM
Interesting!. Did you keep your source information?
Page 2 of 3 1 2 3
Moderated by  SWEET
