The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (buckaroo01, J Lucas, Boilermaker82, 3B, dougs, Hotrod Lincoln, 1 invisible), 455 guests, and 3 spiders.
Forums48
Topics117,145
Posts936,036
Members42,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
What engine do I have #1337245 Tue Dec 10 2019 11:26 PM
Athab3 Offline OP
hello forum, .My 55 GMC came with a 6 cylinder engine # on plate by Dist is 135762,cant find out what size etc Anyone ? Athab3
Have 55 GMC 9300 short box step side .Needs restoring but starts and drives ,no brakes, also have 59 GMC 9380 with very good cab for parts.have been doing MGA's all mjy life so this is new to me
Re: What engine do I have [Re: Athab3] #1337250 Wed Dec 11 2019 12:53 AM
KEVINSKI Offline
MGA s I have a MGB .Your engine will have casting numbers on the block and head that will help with identifying there is a site that lists the cast numbers to years and applications . The number on by the distributor if yours is a Canadian truck like mine won’t be the same as the American made trucks
kevinski 1954 GMC 9300 Welcome to the virtual Garage
Re: What engine do I have [Re: Athab3] #1337279 Wed Dec 11 2019 02:17 PM
EdPruss Offline
A Chevy engine, so use various casting numbers to ID.
Ed
Re: What engine do I have [Re: Athab3] #1337285 Wed Dec 11 2019 03:52 PM
Athab3 Offline OP
thanks guys, I think I should replace the clutch assy and bearing before reinstalling the drive train .Just wondering if they would all take the same parts. Athab3
Re: What engine do I have [Re: Athab3] #1337287 Wed Dec 11 2019 03:57 PM
Athab3 Offline OP
Kevinski, Good morning ,I have a 59 A coupe and a 59 A roadster at the moment .Also a 74 B that I am using the engine and tranny for the 59 A Coupe. Athab3
Re: What engine do I have [Re: Athab3] #1337300 Wed Dec 11 2019 05:48 PM
Frank50 Offline
Athab3, you say "engine # on plate by Dist is 135762". Do you mean the flat machined surface, or a separate plate/ tag affixed to the engine?
Professional Novice
Re: What engine do I have [Re: Athab3] #1337307 Wed Dec 11 2019 06:51 PM
Athab3 Offline OP
Morning Frank50, the number is on the flat machined surface . Athab3
Re: What engine do I have [Re: Athab3] #1337317 Wed Dec 11 2019 09:21 PM
KEVINSKI Offline
Nice MG , Google 235 casting numbers for your truck engine and you will see the information and will be able to tell approximately the year of your engine
Re: What engine do I have [Re: Athab3] #1337379 Thu Dec 12 2019 12:27 PM
Frank50 Offline
This probably doesn't help since you have a Canadian truck. Their numbering system is all different from the US system.
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Still, the number location information is valid.
Also see attached image that may add something helpful.
Professional Novice
Re: What engine do I have [Re: Athab3] #1337478 Fri Dec 13 2019 04:44 AM
Fox Offline
Is there a casting number on the lower front right of the block? Usually that’s where I’ve found them on my 261’s from the Great White North. If not, there may be a casting number hidden near the back right beside the starter. If there, the numbers will be very small (about 5/8” tall) and likely covered with layers of gunk. Very hard to find and see whilst in the truck.The one 261 block I have has a number here and it is a ‘57. I bet yours is near the back as well.
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
