The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (forman, 2and4wheels, Bill Trotter, carbking, bartender, 2 invisible), 913 guests, and 3 spiders.
Forums48
Topics117,094
Posts935,541
Members42,776
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Speedy sleeve for stock 1/2 ton rear axle oil seal surface #1337040 Mon Dec 09 2019 02:11 PM
posey Offline OP
Anyone have a source for this part. Thank you
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337041 Mon Dec 09 2019 02:19 PM
tclederman Offline
Boltergeist
What make/year 1/2 ton truck?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: tclederman] #1337045 Mon Dec 09 2019 02:43 PM
posey Offline OP
1954 chevy 1/2 ton truck
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337054 Mon Dec 09 2019 03:56 PM
EdPruss Offline
Speedy seals, etc., are available by dimension.
Ed
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337057 Mon Dec 09 2019 04:24 PM
posey Offline OP
I guess the other question would be is how do you install the sleeve when you cannot fully utilize the installation Cap part since the axle gets in the way because of its length. Hope that makes sense.
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337074 Mon Dec 09 2019 06:30 PM
truckernix Offline
I did this on my 38 Master, which is very similar. I used a pipe and a rubber mallet to drive the sleeve on. It was tricky because of the following problem: If you don't drive it down far enough the axle will not go into the bearing far enough to install the C clip. When the sleeve was driven far enough, the end if the sleeve did not sit under the lip of the old style seal. However a new modern style seal had the lip further towards the outside and it worked perfectly. I looked up the sleeve online at the manufactures website.
1951 1 Ton Completed
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337078 Mon Dec 09 2019 06:54 PM
posey Offline OP
Thanks, does any one have some kind of quick calculation of how to measure for the new sleeve so you get the one that's not too big or too small?
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337158 Tue Dec 10 2019 02:56 AM
EdPruss Offline
Electronic calipers that measure in thousands of an inch are reasonably priced, lots of uses. Micrometer is more accurate but not required.
Ed
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337241 Tue Dec 10 2019 10:41 PM
Hotrod Lincoln Offline
Boltergeist
Since the speedy sleeve will increase the diameter of the axle shaft by few thousandths be sure you only cover the seal lip area, not the part of the axle that fits through the bearing. It might be necessary to narrow the sleeve a little to be sure you only cover the seal area of the axle, not the load-bearing part.
There's also 3 7/8" diameter sleeve available that would fit the rear main bearing seal area on a 216/235/361 crankshaft. I'm not sure it would work with an OEM rope or rubber seal, but the engines I'm machining for the full circle lip seal would definitely be a candidate for a non-wearing stainless steel crankshaft sealing surface on an engine buildup!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface [Re: posey] #1337288 Wed Dec 11 2019 04:22 PM
posey Offline OP
Is there anyone that may have the dimensional "stock" diameter specs for a 1954 chevy 1/2 ton rear axle at the bearing sealing surface near the wheel hub? Thanks
Page 1 of 3 1 2 3
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
