The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (classicchevs, Johnny N, 1 invisible), 352 guests, and 3 spiders.
Forums48
Topics117,113
Posts935,753
Members42,781
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: oil pan interchange 216 - early 235? [Re: Hotrod Lincoln] #1336612 Fri Dec 06 2019 02:05 AM
Tyler Watts Offline OP
Jerry,
Just a pinhole. I will eventually be pulling the pan, cleaning it out, and checking out the integrity of the metal from the inside. I just need to keep this car moveable right now. I did grind down to clean bare metal an area about 2" diameter around the hole, and cleaned it off with brake cleaner right before I spread the epoxy on. I'm pretty confident it will hold as long as I need it to. The nice thing is that I only drive this car a few miles at a time, so I'll be able to keep an eye on it to see if it springs a leak again.
1953 3600 Pickup
1946 Fleetline Aerosedan
1950 Fleetine Deluxe w/ Powerglide
Re: oil pan interchange 216 - early 235? [Re: Tyler Watts] #1336614 Fri Dec 06 2019 02:21 AM
Frank50 Offline
I patched a 216 oil pan with JB Weld myself many years ago, and it worked fine. Stopped the leak. I did remove the pan and clean it inside and out as best I could, as Jerry mentioned. And, sometimes a quick fix IS necessary to keep something going. Good luck with it.
Professional Novice
Re: oil pan interchange 216 - early 235? [Re: Tyler Watts] #1336656 Fri Dec 06 2019 01:04 PM
panic Offline
Just a pinhole
Pop rivet
Re: oil pan interchange 216 - early 235? [Re: Tyler Watts] #1336663 Fri Dec 06 2019 02:34 PM
Pre '68 Dave Offline
A sheet metal screw with a rubber gasket on it may be a easy temp fix.
My Blog
Re: oil pan interchange 216 - early 235? [Re: Tyler Watts] #1336680 Fri Dec 06 2019 05:06 PM
Hotrod Lincoln Offline
Boltergeist
Unless you use a huge sheet metal screw or pop rivet, you'll definitely need a new oil pan before you're done. The metal surrounding the hole will be paper thin and unable to hold a repair tightly enough not to leak again.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: oil pan interchange 216 - early 235? [Re: Tyler Watts] #1336779 Sat Dec 07 2019 02:54 PM
JB Qwik seems to be holding up pretty well so far. I spread it pretty wide and made sure it was pretty thick right over the hole. I ground down to clean, bare metal and then cleaned the application site with brake cleaner, so I'm confident I got a good bond. I figure when I pull the pan I can clean the inside really good, and then reinforce the patch on the inside; if that looks unfeasible I'll see about getting my hands on a good 235 pan with troughs.
Thanks for all the feedback.
1953 3600 Pickup
Page 2 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
